The mk7 GTI revealed...
Randum
Post by Randum » Thu Sep 27, 2012 9:34 am
Taken from http://www.golfmk7.com/forums/showthread.php?t=24
(tons of pictures)
Press release:
New Golf GTI produces 217 HP in standard version and 227 HP with performance pack
Production version of seventh Golf GTI debuts with new progressive steering
Wolfsburg / Paris, 27 September 2012 – Paris is now the city of the Golf GTI. Four years ago, the sixth generation of the best-seller made its debut here – still as a concept car. Now, in autumn 2012, Volkswagen is presenting the seventh generation Golf GTI in a premiere at the Mondial de l’Automobile in Paris – also as a concept car. In doing so, Volkswagen is opening another window to the immediate future of the most successful European car model series, because another car being shown to a global audience in the French capital at the same time as the GTI is the near-production concept of the new Golf BlueMotion. The new Golf GTI will be launched into the market in early 2013.
One GTI, two power levels
217 HP and 227 HP. The concept of the next Golf GTI is powered by a further advanced engine from the EA888 series – a two-litre turbocharged direct-injection petrol engine with 162 kW / 217 HP. A new option: for the first time in the iconic sports car’s history, a performance pack will be available as a factory-installed option. In this version, the engine’s maximum power is boosted to 169 kW / 227 HP. Both GTI versions are equipped with a Stop/Start system as standard, they fulfil the EU-6 emissions standard that takes effect in 2014 and – with a 6-speed manual gearbox – they attain the same low DIN fuel consumption of 6.0 l/100 km (39.2 MPG) (CO2: 140 g/km). Compared to the previous model (155 kW / 210 PS), the combined fuel consumption of the new Golf GTI is therefore reduced by 1.3 litres per 100 km or 18 per cent. A 6-speed dual-clutch gearbox (DSG) is available as an option for both power levels. The recognised high agility of the Golf GTI has been increased once again in the new model compared to the previous model – in two stages:
Stage 1 – standard GTI: The 217 HP base version now produces 7 HP more than the previous model. At the same time, its maximum torque was increased by an immense 70 Nm (52 lb-ft) to 350 Nm (258 lb-ft). This value in the new Golf GTI is exactly the same as that of the previous Golf R, which was powered by an engine from another TSI generation. Equipped in this way, the Golf GTI makes its appearance with impressive flexibility values: in fourth gear, the Golf GTI accelerates from 80 to 120 km/h (50 mph to 75 mph) in 5.0 seconds; in fifth gear it takes 6.0 seconds. Other data that must not be overlooked in a GTI: the new one accelerates to 100 km/h (62 mph) in 6.6 seconds and reaches a top speed of 246 km/h (153 mph).
Stage 2 – Performance GTI: Those choosing a Golf GTI with the performance pack ignite the second stage. As mentioned, the car’s power is increased by 7 HP here, while its maximum torque is identical. The 227 HP of power enables a top speed of 250 km/h* (155 mph) and just 6.5 seconds for the sprint to 100 km/h (62 mph).
New front axle differential lock and progressive steering
The performance pack not only offers a plus in power, but also a plus in handling: instead of 16-inch brakes, the GTI is equipped with 17-inch brakes here (with GTI badges on the callipers) and a front axle differential lock (VAQ) that is also being offered for the first time in this form.
Front axle differential lock. The electronically controlled lock has a positive effect on active safety and driving dynamics, because it practically prevents the power-related understeer that can occur in powerful front-wheel drive cars. This makes handling precise, and has a stabilising effect in load-alteration induced oversteer. The reason: VAQ increases the power to the wheel on the outside of the curve, which also optimises the vehicle’s speed through bends. Traction is also improved when driving on loose and wet road surfaces and in turning situations.
Progressive steering. The new progressive steering system is celebrating a world premiere in the Golf GTI. It is a standard feature for both power levels. Thanks to this steering system, the driver can turn the car through a desired radius with fewer turns of the steering wheel. In other words, the driver does not need to reach over the wheel as often. That may sound simple, but it is revolutionary. The reason is that conventional steering systems work with a constant gear ratio. The new steering of the Golf GTI, meanwhile, operates with a progressive steering gear ratio. This noticeably reduces steering work when manoeuvring and parking. On country roads with lots of bends, and when making turns, the driver experiences a benefit in dynamics due to the more direct layout.
Technically, progressive steering differs from the basic steering system due to the rack and pinion’s variable tooth spacing and a more powerful electric motor. Its functional difference: unlike with constant steering ratios, which by necessity always represent a compromise between dynamic performance and comfort, here the steering rack’s toothing is significantly modified by the steering stroke. As a result, the transition between indirect steering behaviour in the mid-range (straight-line driving) and direct steering behaviour at larger steering wheel angles is designed to be progressive, which, as mentioned above, enables significantly more agile steering behaviour in dynamic driving situations. This results in smaller steering input angles when parking for greater convenience and comfort.
Variable ratios have long been known in the area of hydraulic steering systems; however, the tuning of such a steering system is subject to very tight limits, so that the driver is not overtaxed by the transitional behaviour. With the Golf GTI’s progressive steering system the situation is completely different: the combination of the steering rack’s progressive steering ratio and the tuning potential of an electro-mechanical steering system is systematically exploited in the GTI to realise optimised steering behaviour that is sporty yet practical in everyday driving. In all other Golf cars, progressive steering is offered as an optional feature.
Exterior – features and styling
GTI insignia. Like all six Golf GTI generations before it, the seventh generation concept car being shown in Paris is distinguished from other Golf models by numerous additional equipment features and classic GTI insignia. On the exterior, these include the red painted brake callipers, a GTI-typical honeycomb structure for the air inlet screens, smoked LED rear lights including LED licence plate lighting as well as chrome 80 mm diameter tailpipes on the left and right. Some features have been characteristic since the days of the first Golf GTI, for example the production colours Red (“Tornado Red”) and “Black” and an optional white exterior (“Pure White” as special colour). Volkswagen has further developed the classic GTI wheels “Denver”, “Detroit” and “Glendale” whose styling characteristics from the previous model have flowed into the design of the new machine-polished 17-inch “Brooklyn” alloy wheels; they have a lighter visual look and are in fact lighter in weight. The wheels are fitted with 225/45 size tyres. 18-inch wheels will also be available on the GTI as an option.
GTI styling. Overall, the seventh generation Golf is also visually more dynamic than the previous one. The objective of the designers was to develop an even more striking and sporty character into the new Golf GTI – the goal was to give the GTI a lower, wider image with a more challenging character. Volkswagen Design developed numerous individual, detailed solutions for the new Golf GTI and integrated them harmoniously into the overall visual concept. Important here is the fact that the GTI-specific design elements are not simply “add-on” solutions, but are integrated into the overall design of the car. One significant reason for this is that the GTI was designed in parallel to the “normal” Golf – and this made it possible to coordinate perfectly the differentiating characteristics of the two model versions.
At the front end, with its LED fog lights specially customised for the GTI, a powerful and significant GTI element attracts attention, which has now been fully reinterpreted: the red stripe. In the first generation of the car it surrounded the rectangular radiator grille completely. On the sixth generation GTI there were two red stripes, which framed the grille at the top and bottom. Now, on the seventh generation car, the red stripe marks the lower edge of the radiator grille, but for the first time it extends further to the left and right, up to the housings of the bi-xenon headlights. So, the red line now runs completely across the front end.
In the far lower section of the bumper, beneath the crossbar painted in body colour, the black air inlet (with a honeycomb pattern screen) is no longer framed by a black area, rather by surfaces painted in body colour, which makes the air inlet stand out more powerfully. At the same time, the three lateral black aerodynamic fins beneath the headlights play a more prominent role in the front end styling. Another detail fitting in with the precisely contoured styling is the black splitter (lower edge of the front spoiler), which is familiar from motorsport. Also styled in black are the side sills and the rear diffuser. These quasi wrap-around black elements give the Golf, which is equipped with a GTI sport chassis (15 mm lower ride height), an even fuller stance on the road.
Another example of the harmonious integration of GTI-specific elements is the new roof spoiler design, which is considerably larger than its counterpart on Golf versions with less powerful engines and which is integrated to be flush with the bootlid and the body. For the first time, the sporty Volkswagen also has, in addition to the GTI badges at the front and rear, red plates on the front wings at the height of the character line with the same typographic interpretation of the GTI logo that has been used for decades.
Interior – features and appearance
GTI insignia in the interior. The very first GTI had this feature: seat covers in legendary tartan pattern. The sixth generation Golf GTI used “Jacky” fabric, and in the transition to the new GTI generation this has been redesigned and is now named “Clark”. Naturally, the tartan pattern was retained. The sport seats (in front, with sliding drawers under the seats) have exceptionally good ergonomic properties. Step in, sit down, adjust the backrest angle and the distance to the steering wheel, buckle up, and you’re all ready to drive. Nonetheless, the front seats also have height adjustment and a manually adjustable lumbar support. Red decorative seams in the area of the seats and the gear shift trim provide a sporty contrast; the black roofliner that is always part of the GTI emphasises the sporty layout of the interior.
GTI features. Along with its many standard features such as air conditioning, fatigue detection and the “Composition Touch” radio system (with CD card slot and AUX-IN interface), other GTI-specific features refine the standard version interior as well: typical of a Golf GTI are the customised sport steering wheel and a special gear shift grip. The latter is once again reminiscent of a golf ball, which also makes it a tribute to the first GTI just like the new leather-trimmed steering wheel design. The sporty flat-bottomed steering wheel with its three metal spokes and trim in high-gloss black has a lightweight look, and it is remarkably handy and easy to grip. On its two cross spokes it has multifunction keys as standard, and at its centre – in contrast to all other Golf steering wheels – it has a round impact absorber whose form is similar to that of the component in the first GTI.
Also making a strong statement is the GTI instrument cluster with a colour display and independent graphics of its instruments. It is no coincidence that it resembles high-end chronographs. The GTI-specific look of the interior is completed by red ambience lighting, special trim strips and panels (trim strips in the front doors with ambience lighting), brushed stainless steel pedals and foot rest (on left), door sill entry plates in front with a stainless steel application and ambience lighting that is also integrated here.
Image Credit to http://www.golfmk7.com/forums/showthread.php?t=24
Thoughts?
Dybz
Re: The mk7 GTI revealed...
Post by Dybz » Thu Sep 27, 2012 9:56 am
interior: win
exterior: win (minus red stripe through headlights and side badging on front fender)
drivetrain: mediocre, but expected. 217 hp or 227 with the "performance pack"... really? when the focus ST is coming with 247 hp, and the MS3 had 265 hp 5 years ago? also, pretty sure the turbo will still be a k03 size, so that sucks. APR did imply that an oem upgrade will be easy, but we shall see with the new head design integrating the exhaust manifold. plus that funky dual fuel injection system... more stuff to break, or potentially capable of handling more power due to two fuel streams? although the performance pack does sound interesting in that it actually gets an actual LSD for the first time. bigger front brakes on the performance pack are always nice.
suspension: being tied down to make the car seem lower... fail. (or was this for shipping or something?)
my thoughts: getting a golf R as long as they have a defeatable traction control. they might actually be cheaper than the previous gen R's due to the MQB platform, so that would be nice. plus the R will now come with a new engine instead of a 6 year old design like previous one did.
Hybrid > Diesel
Post by got desl? » Thu Sep 27, 2012 1:14 pm
There are a lot of awesome new things implemented with the new GTI.
Although yes it is down on power, this has never been VW's forte comparative to other brands and cars in the same group. The more interesting number to me is the TRQ figure, being all the way up to 258. That is a huge increase, allowing it to really shine through out the range of the RPMs.
The bigger brakes will be a nice touch too, unfortunate that one would have to now run 17s come winter time though.
Like Dybz said exterior and interior are major wins....hopefully we get the TC button as well :D
The suspension with tie downs throws me off, hopefully it is only for transport and someone forgot to take it off....like the clips the MK6s had in the suspension as well when shipped.
Overall I think it is a great update/redesign. Bringing back many older characteristics of the GTi and implementing a lot of new things.
The two year wait will be tough for this one.....now where is the all important GTD and AWD Diesel Powered Golf R :thumbup:
Randum
Post by Randum » Thu Sep 27, 2012 2:07 pm
I have to say exterior I have only one complaint, its that side badge thing - Like the new wheels, they do look a lot like the gallardo wheels though, which is fine.
Power wise, yeah the increased torque is nice, and two fuel lines you said? So I assume that also allows a little more overhead for someone interested in aftermarket improvements too?
I don't think its as drastic as the mk5-6 in terms of styling IMO.
Overall, pretty cool, I'm looking forward to test driving it. I have been so happy with my mk6, it would have to really impress me when I got in the seat. And hopefully some parts are interchangeable too.
hemidesign
Post by hemidesign » Thu Sep 27, 2012 2:41 pm
Holy shit, car looks great, every detail came out really impressive..
Vw designers are really good, no doubt
The wheels selection from every color looks great, car interior looks stunning, the steering wheel? The best ever...
The only downside I see here was the acc and brake pedals.. way too small and ugly look
Can't wait to see this car live.. I might go to Detroit autoshow January next year just to photography the new GTI
Dybz
Post by Dybz » Thu Sep 27, 2012 2:43 pm
the two fuel systems are to combine the pros of the direct injection and port injection systems. i think port injection is better at high loads/revs while direct injection is better at part load. also, having port injection is supposed to prevent the carbon buildup issue the MKV/MK6 have been having.
as for the torque getting bumped, yeah, it's nice, but nothing a quick tune couldn't get you. i'm more upset by the car most likely still coming with a k03, not so much the actual power output on paper. k03 means we're still limited in tunable power. if we could get a nice k04 setup with potential to tune to 350 or so at the crank... now that would be great.
Hybrid > Diesel
Post by got desl? » Thu Sep 27, 2012 3:33 pm
Dybz wrote:the two fuel systems are to combine the pros of the direct injection and port injection systems. i think port injection is better at high loads/revs while direct injection is better at part load. also, having port injection is supposed to prevent the carbon buildup issue the MKV/MK6 have been having.
Yeah I see where you're coming from with regards to the K03 issue. Curious to know how all the new engine tech will help/hinder tuning capabilities on the GTI's now. Nice to see that the MPG's are getting bumped up as well...36mpg for highway is quite nice for the package you're getting, that low end trq is really the huge benefit to that.
S4SHO
Post by S4SHO » Fri Sep 28, 2012 12:55 am
I'm most disappointed in the power figures. As stated before, with the Focus ST and MS3, it's just not enough in this day and age. Yes, nothing a tune/DP can't take care of, but still I feel like they're playing quite a bit of catch-up there still. I can't say I'm sold yet over the MK6, but I'll reserve judgement fully until I drive one :)
04.5 Jetta GLI 1.8T, 209whp/266wtq
06 Pontiac GTO
http://www.mobileoneinc.com
Post by got desl? » Fri Sep 28, 2012 7:38 am
S4SHO wrote:I'm most disappointed in the power figures. As stated before, with the Focus ST and MS3, it's just not enough in this day and age. Yes, nothing a tune/DP can't take care of, but still I feel like they're playing quite a bit of catch-up there still. I can't say I'm sold yet over the MK6, but I'll reserve judgement fully until I drive one :)
The thing is though, GTI's have always been behind in the power game, along with the "R" models as well. The R32 came out just as the STi and Evo's were here in the States. R32 only had 240hp compared to the 300 of the STi and 270 of the Evo.
But the thing is the R32 was still a favorite among critics, and the same thing goes for the GTI against the MS3. Both generations of the MS3 have been beat out by the GTI due to the fact of how refined it is. I can't speak for the Focus ST, but I know that the MS3 is not as great of a package as the GTI. It has a ton of power and a few nice touches, exterior styling not being one of them.
Honestly that bump in torque will really help even out the overall power band and make the car a lot quicker and more enjoyable to drive. I mean with the power pack, 227hp and 258trq those are nice numbers for the GTI, and I think it will be able to hold its own quite well against the ST and MS3.
Dybz
Post by Dybz » Fri Sep 28, 2012 9:32 am
Good news is that at least APR said there is an easy OEM swap for the base 2.0T. Probably coming from the upgraded S3/Golf R engine like we have now for the K03->K04 swaps.
Hybrid > Diesel
hemidesign
Post by hemidesign » Fri Sep 28, 2012 12:58 pm
If I'm getting this car, the Mk7.. I would do a Brawn GP.. (didn't have time to photoshop brakes pads and rotos)
White VMR, lowered.. etc etc...
sample design below.. enjoy!
Randum
Post by Randum » Fri Sep 28, 2012 3:51 pm
Nice PS job on that!
SteverK
Post by SteverK » Tue Oct 02, 2012 10:12 am
Does it come in orange?
Steve
2005 A4 1.8t Quattro
2007 GTI Farenheit Edition 602/1200, gone but not forgotten
2003 A6 4.2l Quattro, gone
Dybz
Post by Dybz » Tue Oct 02, 2012 10:31 am
Hybrid > Diesel
hemidesign
Post by hemidesign » Tue Oct 02, 2012 2:11 pm
A better option than the orange one.. :snap:
SteverK
Post by SteverK » Thu Oct 04, 2012 10:28 am
:laugh: :laugh: :laugh:
Steve
DasTeknoViking
Post by DasTeknoViking » Thu Oct 04, 2012 12:16 pm
love the Wacky Racers edition... MAKE IT !!
hemidesign
Post by hemidesign » Sat Oct 06, 2012 11:14 am
I may build the Wacky Races Edition one day.. hahaha :rofl:
btw, I don't think will be in orange, unless if they make Fahrenheit version again..
Dybz
Post by Dybz » Mon Oct 08, 2012 11:24 am
hemidesign wrote:I may build the Wacky Races Edition one day.. hahaha :rofl:
pffft... pretty crappy pshop there. mine is way better. if you want i am willing to teach you how i did mine. you obviously need some more practice, but you're getting there.
Hybrid > Diesel
corrado917
Post by corrado917 » Thu Oct 11, 2012 7:43 pm
Like the color..
By the way,the GTI should not be far from this..
http://www.youtube.com/watch?v=U8B2lx0-cBw&feature=plcp
MKVI GTI
Christopherlewis
Post by Christopherlewis » Sat Feb 09, 2013 1:17 am
Randum wrote:Taken from http://www.golfmk7.com/forums/showthread.php?t=24
(tons of pictures)
Press release:
led bulb attain the same low DIN fuel consumption of 6.0 l/100 km (39.2 MPG) (CO2: 140 g/km). Compared to the previous model (155 kW / 210 PS), the combined fuel consumption of the new Golf GTI is therefore reduced by 1.3 litres per 100 km or 18 per cent. A 6-speed dual-clutch gearbox (DSG) is available as an option for both power levels. The recognised high agility of the Golf GTI has been increased once again in the new model compared to the previous model – in two stages:
Thoughts?
It looks fantastic. I will read some more reviews about and then will decide to purchase it or not?
kailey
Post by kailey » Tue May 08, 2018 2:35 am
environment, healthy coach bags personality nfl chiefs and psychological nfl titans development coach outlet en ligne and coach outlet harmonization nike air max 2015 in iphone 4s cases line adidas with the new balance shoes age characteristics.We can not nike mercurial vapor control nike air max the vibram shoes weather, timberland shoes but we can thomas sabo uk change the occhiali oakley mood; we can air jordans not change adidas shoes the face, but nfl rams we puma can show mcm handbags a the north face smile; belstaff we asics gel can nfl jets not nfl texans control others, but oakley sunglasses cheap we roche run can prada outlet control their own; we michael kors can tods mens shoes not change ferragamo shoes the environment, but we can change ray ban sunglasses their own; nfl lions we can not predict jerseys from china tomorrow, asics but we pandora bracelets can use today; we hollister co can not determine birkenstock taschen outlet the plein outlet length of birkenstock taschen deutschland life, cheap jerseys but bottega veneta we can control adidas sneakers its coach outlet width.Heart can nfl redskins not reebok tolerate burberry handbags others, in fact, hurt their own; guess jeans all day burberry sale complaining about swarovski jewelry fate, as ralph lauren uk real kate spade efforts. Create a good womens hoodies life needs a good juicy couture attitude, long champ maintaining asics harmonious jordans for sale interpersonal relationships mizuno running need converse outlet a good attitude, the converse achievements of cheap basketball shoes the polo ralph lauren outlet future nfl bills needs knicks jerseys of mbt shoes outlet the future ugg australia good pandora attitude, let nike outlet us start from ourselves, fred perry every moment hermes outlet of every versace shoes outlet day pandora rings is nike huarache changed from the louboutin start, juicy couture clothings for houston rockets the new balance achievements of bcbg dresses their birkenstock outlet own bright future.I pistons jersey sat in michael kors purses the fall nike.de of coach outlet arms, ralph lauren factory store in the north face outlet memory of nfl packers that ralph lauren shirts field in toms shoes outlet the dansko shoes shallow autumn free run blooming, soccer outlet online Cantabile michaelkors.com poetic lacoste polos aesthetic air jordan retro and solitude. --InscriptionShallow autumn cool earthI'm with nba jerseys you face to giuseppe shoes face. Watching kevin durant shoeskobe bryant shoes this season of adidas neo full and north face honest.But mcm outlet I chi hair do gucci womens shoes not know that nfl seahawks looking oakley sunglasses first zero howling Araara. memphis grizzlies Me ray ban sunglasses and adidas.de you, run in the opposite cheap nike shoes direction, missed polo ralph lauren the michael kors handbags season.GAO is still the michael kors outlet online sale sky is still pandora landing jerseys from china leaves. nfl panthers Lie longchamp sadness ecco women shoes lined unfeeling.I know I unload nfl broncos heavy tonnages of love babyliss in this autumn. michael kors bags Only oakley outlet for nike.dk the nba jerseys outlet abundance and enrichment designer handbags of prada the burberry outlet online season. But nfl colts unexpectedly, replica watches such flat iron as fendi outlet online going uggs through softball bats a michael kors outlet online difficult nike roshe journey.After philadelphia 76ers jersey all, I portland trail blazers was homeless from nike.com outside the season, philipp plein clothes such burberry handbags as cheap jerseys wrinkles sounded replica watches bare hillside cheap oakley sunglasses tracts cheap true religion of converse chucks age spots. Withered almost to cruelty.As levis outlet store if prada outlet there burberry handbags has charlotte hornets jersey never nfl jaguars been barbour women jackets lonely in the sky burning a michael kors outlet online lot michael kors of engulfed air jordan my nfl jerseys soul wreckage.Behind the years, baseball jerseys is still in ray ban sunglasses the russell westbrook jersey text rayban sunglasses of marc jacobs outlet the hilfiger bumps, and I have kobe bryant jersey nothing ray ban sunglasses to hollister kids rows fake rolex of a list of cheap true religion stories.I ralph lauren try jack wolfskin outlet online to longchamp taschen want coach outlet online to nfl azcardinals go farther, in nfl ravens faraway places, burberry handbags do a nba jerseys pull ray ban outlet farewell.Shallow autumn dreamDo not always in my toms shoes words to find my shadow, how could lunette oakley pas cher I polo ralph lauren let myself suns jerseys do nfl dolphins word jordan shoes in oakley outlet online the giuseppe zanotti puppet?Every cheap oakley sunglasses expression, are nothing air max but a tea ralph lauren millet barbour women jackets style. nike air max It seems I Fall nfl bengals in bos jersey love with nfl chargers this ralph lauren text, michael kors bags even hopeless.Do not underestimate this nike max shallow autumn, I san antonio spurs caressed baseball bats its vans shoes temperature, michael kors purses it mont blanc seems to ralph lauren uk have michael kors touched those who have mcm backpack outlet past. reebok shoes With nfl eagles you, hollister with roshe run me, rolex I could nike free run not c&c beanies wholesale bear throwing this thread warmth.I hogan always nop jerseys believe that rayban I do not hollister online shop deutschland have guess bags outlet a barbour mens jackets biting affair, as new balance store a timberland homme blooming belstaff mens jackets blooming, tommy hilfiger online shop deep and prada sunglasses shallow shoes on sale up early to salomon schuhe see louboutin shoes the belstaff sale sunrise rolex replica idea air jordan shoes appears, cheap glasses you thomas sabo can roshes do? If guciheaven you live in louboutin the city, roshe run in timberland boots the ray ban outlet morning I abercrombie do northface not know christian louboutin where nfl patriots to burberry play, swarovski had calvin klein changed the quality - burberry online shop Condominium claimed horizon, gray coach outlet dust air max 95 in nfl saints the north face jackets air nba jerseys there longchamp outlet is always a nike store greasy true religion jeans outlet feeling toms outlet tired, there is ed hardy clothing always michael kors play cheap oakley the new balance ghost of gasoline, toms outlet even red bottoms though ray ban sbocco cover utah jazz their nfl bears ears, can not hollister hold nike air max 2014 a www.tommyhilfiger.nl taxi horn, there parajumpers outlet online is no nike air max real night, nfl giants naturally it mcm bags does not hilfiger outlet matter really dawn michael kors purses ...... no coach factory outlet online dirt, no mountains, michael kors v?skor wilderness, no jordan release dates Jia nfl cowboys Qing, nike mercurial only the rough hogan shoes outlet black washington wizards cement cheap jerseys and true religion reinforced brick fred perry shoes you polo ralph lauren outlet unaware of polo ralph lauren the "new", nike free shoes even though north face pas cher his woolrich outlet online eyes open, supra shoes as hugo boss outlet in nfl vikings the air max 90 still tory burch sale drowsy ray ban wayfarer sleep, but, under armour curry in most cases, montre pas cher we ignore the existence of ralph lauren tracksuits everything tommy hilfiger outlet stores around: can dallas mavericks jersey not see blue sky, white clouds, michael kors australia can not cheap michael kors see the pandora jewellery trees, flowers ...... nike roshe ...Emerson hermes bags in "On kanye west shoes the Nature" Mean: "In thomas sabo fact, very few adults oakley sunglasses outlet can air max shoes really milwaukee bucks see nature, most cheap oakley people nike tn requin do replica handbags not look replica rolex at swarovski the michael kors canada sun carefully, at most they wholesale handbags are cheap ray ban just skimming pandora over armani clothing the coach outlet online sun jack wolfskin would huaraches illuminate adulthood. coach outlet sale the human the north face eye, polo outlet online but nfl 49ers it will shine into the dsquared2 jeans soul michaelkors.com through salvatore ferragamo the eyes of a stone island store child. people really oakley sunglasses outlet love oakley sunglasses nature, swarovski is the longchamp handbags kind michael kors outlet of bcbg max azria feeling louboutin outlet inside and outside swarovski crystal are coordinated person, still adidas shoes outlet playful spirit is the kind of real nike air force adult iphone 5 cases people. mont blanc pens "However, minnesota timberwolves in celine handbags modern community who bottega can do it? nike air force Like valentino shoes outlet Flaubert, tommy hilfiger Thoreau, Edwards ...... I even zapatillas nike sure, if they were prada handbags alive converse shoes today, and ralph lauren outlet we must nike.se have chicago bulls the same.Therefore, no true religion outlet matter ralph lauren when cheap eyeglasses and nike air max where, we can only restore childlike denver nuggets curiosity versace outlet and innocence? north face outlet Only sac jerseys the ralph lauren online clear nfl buccaneers sunlight ralph lauren polo as hermes birkin children can katespade outlet be north face backpacks found in mcm bags this supra footwear world, the north face in michael kors outlet online sale order to michael kors outlet online see coach factory online more skechers womens shoes than usual, in adidas.se order to watch coach factory outlet online the event coach black friday from dsquared2 shoes the adidas superstar most mundane nets jersey to skechers the rayban magical and replica watches beautiful. fitflop The fidget spinner adult mizuno running shoes world, coach factory outlet online almost barbour outlet lacking coach purses a coach factory outlet online real oakley vivid christian louboutin shoes natural, only ray ban zonnebril the rules longchamp of the game, air max only with people cheap michael kors of cheap oakley sunglasses experience chrome hearts jewelry and salvatore ferragamo logic.However, honorable shop coach factory adults, links of london bracelets it watches must swarovski australia be the christian louboutin kind of new balance "adulthood still playful jimmy choo shoes spirit of man", it must mia jersey be able kate spade outlet to toms shoes seize their one nike free 5.0 day marc jacobs handbags of people.When nfl falcons one true religion jeans women day a under armour ua shoes monk burberry clock air max 2014 hit oakley prescription one burberry outlet online thought givenchy bags outlet dawdle; ferragamo the relojes especiales other longchamp outlet is the body in its place, not nike huaraches their government, instead burberry outlet of nike outlet store complaining, high this treatment, the good job, also said jerseys from china that when the leadership is not simple, tory burch shoes if I have the nfl raiders opportunity Hermes to when scarpe hogan the timberland outlet leader, orlando magic I am kate spade outlet online not worse than puma outlet store them, ray bans and soccer shoes some ferragamo outlet even think that I nike air can be cleveland cavaliers jerseys a nike online manager, michael kors bags take polo ralph lauren outlet online 100,000 annual hollister clothing store salary, gucci mens shoes how moncler outlet online wonderful!In burberry uk fact there gafas oakley is barbour mens jackets a pandora rings kind indiana pacers of reason, vans outlet any ralph lauren outlet online person in nfl steelers a omega watches position nfl browns of leadership cadres, we should tommy hilfiger say skechers is a ray ban step by gsw jerseys step ray ban according jimmy choo to their ray ban sunglasses outlet ability to uhren break designer handbags out of the free running same operator, toronto raptors he toms outlet carefully than los angeles clippers others, cheap jerseys so vans schuhe he moncler women jackets became oakley the squad leader; the same squad, his burberry outlet online management in place than others, lacoste shirts so ralph lauren outlet he polo ralph became lunette ray ban pas cher a deputy nike air
Post by valladar » Wed Jun 13, 2018 1:05 am
Post by kakakaoo » Fri Aug 10, 2018 8:59 am
Post by valladar » Tue Sep 04, 2018 10:54 am
http://audiobookkeeper.ruhttp://cottagenet.ruhttp://eyesvision.ruhttp://eyesvisions.comhttp://kinozones.ruhttp://laserlens.ruhttp://medinfobooks.ruhttp://mp3lists.ruhttp://spicetrade.ruhttp://spysale.ruhttp://stungun.ruhttp://largeheart.ruhttp://lasercalibration.ruhttp://laserpulse.ruhttp://laterevent.ruhttp://latrinesergeant.ruhttp://layabout.ruhttp://leadcoating.ruhttp://leadingfirm.ruhttp://learningcurve.ru
http://leaveword.ruhttp://machinesensible.ruhttp://magneticequator.ruhttp://magnetotelluricfield.ruhttp://mailinghouse.ruhttp://majorconcern.ruhttp://mammasdarling.ruhttp://managerialstaff.ruhttp://manipulatinghand.ruhttp://manualchoke.ruhttp://nameresolution.ruhttp://naphtheneseries.ruhttp://narrowmouthed.ruhttp://nationalcensus.ruhttp://naturalfunctor.ruhttp://navelseed.ruhttp://neatplaster.ruhttp://necroticcaries.ruhttp://negativefibration.ruhttp://neighbouringrights.ru
http://objectmodule.ruhttp://observationballoon.ruhttp://obstructivepatent.ruhttp://oceanmining.ruhttp://octupolephonon.ruhttp://offlinesystem.ruhttp://offsetholder.ruhttp://olibanumresinoid.ruhttp://onesticket.ruhttp://packedspheres.ruhttp://pagingterminal.ruhttp://palatinebones.ruhttp://palmberry.ruhttp://papercoating.ruhttp://paraconvexgroup.ruhttp://parasolmonoplane.ruhttp://parkingbrake.ruhttp://partfamily.ruhttp://partialmajorant.ruhttp://quadrupleworm.ru
http://qualitybooster.ruhttp://quasimoney.ruhttp://quenchedspark.ruhttp://quodrecuperet.ruhttp://rabbetledge.ruhttp://radialchaser.ruhttp://radiationestimator.ruhttp://railwaybridge.ruhttp://randomcoloration.ruhttp://rapidgrowth.ruhttp://rattlesnakemaster.ruhttp://reachthroughregion.ruhttp://readingmagnifier.ruhttp://rearchain.ruhttp://recessioncone.ruhttp://recordedassignment.ruhttp://rectifiersubstation.ruhttp://redemptionvalue.ruhttp://reducingflange.ruhttp://referenceantigen.ru
http://regeneratedprotein.ruhttp://reinvestmentplan.ruhttp://safedrilling.ruhttp://sagprofile.ruhttp://salestypelease.ruhttp://samplinginterval.ruhttp://satellitehydrology.ruhttp://scarcecommodity.ruhttp://scrapermat.ruhttp://screwingunit.ruhttp://seawaterpump.ruhttp://secondaryblock.ruhttp://secularclergy.ruhttp://seismicefficiency.ruhttp://selectivediffuser.ruhttp://semiasphalticflux.ruhttp://semifinishmachining.ruhttp://tacticaldiameter.ruhttp://tailstockcenter.ruhttp://tamecurve.ru
http://tapecorrection.ruhttp://tappingchuck.ruhttp://taskreasoning.ruhttp://technicalgrade.ruhttp://telangiectaticlipoma.ruhttp://telescopicdamper.ruhttp://temperateclimate.ruhttp://temperedmeasure.ruhttp://tenementbuilding.ruhttp://ultramaficrock.ruhttp://ultraviolettesting.ruhttp://jobstress.ruhttp://jogformation.ruhttp://jointcapsule.ruhttp://jointsealingmaterial.ruhttp://journallubricator.ruhttp://juicecatcher.ruhttp://junctionofchannels.ruhttp://justiciablehomicide.ruhttp://juxtapositiontwin.ru
http://kaposidisease.ruhttp://keepagoodoffing.ruhttp://keepsmthinhand.ruhttp://kentishglory.ruhttp://kerbweight.ruhttp://kerrrotation.ruhttp://keymanassurance.ruhttp://keyserum.ruhttp://kickplate.ruhttp://killthefattedcalf.ruhttp://kilowattsecond.ruhttp://kingweakfish.ruhttp://kleinbottle.ruhttp://kneejoint.ruhttp://knifesethouse.ruhttp://knockonatom.ruhttp://knowledgestate.ruhttp://kondoferromagnet.ruhttp://labeledgraph.ruhttp://laborracket.ru
http://labourearnings.ruhttp://labourleasing.ruhttp://laburnumtree.ruhttp://lacingcourse.ruhttp://lacrimalpoint.ruhttp://lactogenicfactor.ruhttp://lacunarycoefficient.ruhttp://ladletreatediron.ruhttp://laggingload.ruhttp://laissezaller.ruhttp://lambdatransition.ruhttp://laminatedmaterial.ruhttp://lammasshoot.ruhttp://lamphouse.ruhttp://lancecorporal.ruhttp://lancingdie.ruhttp://landingdoor.ruhttp://landmarksensor.ruhttp://landreform.ruhttp://landuseratio.ru
http://languagelaboratory.ruhttp://factoringfee.ruhttp://filmzones.ruhttp://gadwall.ruhttp://gaffertape.ruhttp://gageboard.ruhttp://gagrule.ruhttp://gallduct.ruhttp://galvanometric.ruhttp://gangforeman.ruhttp://gangwayplatform.ruhttp://garbagechute.ruhttp://gardeningleave.ruhttp://gascautery.ruhttp://gashbucket.ruhttp://gasreturn.ruhttp://gatedsweep.ruhttp://gaugemodel.ruhttp://gaussianfilter.ruhttp://gearpitchdiameter.ru
http://geartreating.ruhttp://generalizedanalysis.ruhttp://generalprovisions.ruhttp://geophysicalprobe.ruhttp://geriatricnurse.ruhttp://getintoaflap.ruhttp://getthebounce.ruhttp://habeascorpus.ruhttp://habituate.ruhttp://hackedbolt.ruhttp://hackworker.ruhttp://hadronicannihilation.ruhttp://haemagglutinin.ruhttp://hailsquall.ruhttp://hairysphere.ruhttp://halforderfringe.ruhttp://halfsiblings.ruhttp://hallofresidence.ruhttp://haltstate.ruhttp://handcoding.ru
http://handportedhead.ruhttp://handradar.ruhttp://handsfreetelephone.ruhttp://hangonpart.ruhttp://haphazardwinding.ruhttp://hardalloyteeth.ruhttp://hardasiron.ruhttp://hardenedconcrete.ruhttp://harmonicinteraction.ruhttp://hartlaubgoose.ruhttp://hatchholddown.ruhttp://haveafinetime.ruhttp://hazardousatmosphere.ruhttp://headregulator.ruhttp://heartofgold.ruhttp://heatageingresistance.ruhttp://heatinggas.ruhttp://heavydutymetalcutting.ruhttp://jacketedwall.ruhttp://japanesecedar.ru
http://jibtypecrane.ruhttp://jobabandonment.ru
