I am again satisfied...
brandon002
Post by brandon002 » Thu Dec 02, 2004 3:29 pm
Picked up my 91 GTI last night and I'm stoked. No more cushy B3 for me. I'll post pics soon.. It's a Montana Green 8 valve with ton of goodies on it. Mostly suspension/brake work.
golf97
Re: I am again satisfied... (brandon002)
Post by golf97 » Thu Dec 02, 2004 3:32 pm
let's see some pics man
brandon002
Post by brandon002 » Thu Dec 02, 2004 3:44 pm
I will take some pics tomorrow. For now here is a list of the mods the car came with..> Very recent mods (under 500 miles)> > AMS Chip (used)> Eurosport Cool-Flo intake> Reman. AirFlow Meter> Autotech Strut Bar> Eurosport Rear Stress bar> Eibach 23mm front sway bar (poly center/subframe bushings, new OEM end-links & bushings)> Bilstein Sports & H&R Sport Springs> VR6 strut mounts/bearings> Poly rear shock bearings/bushings (prothane)> All associated parts for shocks/stuts...bump stops, dust covers, washers, nuts, upper front strut bolt is reduced shank dia.> Tie rods & tie rod boots (complete)> Ball joints> Axles (axle bolts)> A-Arms (Autotech poly bushings in front with Audi TT bushings in rear)> I also have new Rear beam bushings with new poly inserts (prothane) that need to be installed.> Front hubs> Rear stub axles> Front & rear wheel bearings> Front knuckles (used)> Front rotors (11" ATE powerslot or whatever they are called)> Rear rotors (8.9" slotted and cross-drilled) BBM I think. I got the 'kit' from someone who totalled their car before using the parts.> Splash shields front & rear> Corrado 11" calipers (Girling 54) & carriers> Hawk HPS pads (front)...to be replaced with Mintex Reds> mkIV Alum calipers in rear (carriers are mkII)> OEM VW pads (rear)> All flex brake lines replaced (OEM parts not SS)> 22mm Master cyl. & resevoir> Brake pressure reg. valve (on rear beam)> e-brake cables> leather e-brake handle cover> FPR (stock 3.0 bar)> Interstate battery (forget which one)> battery cables (mkIII larger gauge, better ends, used from Cali)> Autotech alt. harness wire (2 ga from alt. to battery (+) )> High current ground wires (rockford fosgate wires and terminals)> Coolant temp sensor> Coolant temp sender> Badgeless Single round grille (JOM)> IN.Pro H4 Clears (with relayed wire harness. Harness is actually for the quad set-up)> Osram bulbs...silverstars if I remember correctly (German)> Clear Front turn Signals> Clear/white sidemarker lights> Polk audio DB 6.75" coax's in rear> Polk audio EX3 components in front> Blaupunkt Heidelberg (CD51)> accel. pedal throttle cable bushing> mkIII door handles (chinese...I'll include them anyways)> > 5000-10,000 Miles> > Techtonics SS dual downpipe> Techtonics high flow cat> Techtonics alum. exh (with two straight thru resonators) Flow master muffler (polished SS tip/end tube)> Exh. hangers (two or three chained can't remember now)> vacuum hoses> knock sensor> O2 sensor (with heat shield sheath over entire wire lenght)> brake light switch> Fuel pump (main)> Fuel pump housing> Fuel filter> Fuel lines at fuel filter/pump housing & clamps> All belts including timing belt, tensioner & bolt> Throttle body (reman...hand polished)> > > 10,000-15,000 Miles> > G60 BBS Mesh Wheels (Have a fifth as a spare) (used)> G60 Fender Flares (front & rear)> All body trim replaced> Coolant hoses & clamps> Starter (reman ?)> Valve cover gasket (rubber)> Oil pan gakset (rubber)> Timing belt cover (upper)> All shifter bushings and wearable pieces (including shifter & assoc. parts)> 16V All black w/ red stripe door cards (pleather) (used)> 16V Leather steering wheel (used)> > Sparco grip pedals (not installed)> > approx. 60,000 Miles> > Clutch, flywheel & clutch cable > Radiator> Alt. (reman)> Fuba antenna (complete)> Door handles (stock)> > Extras> > Ported, Polished and gasket matched head (assembled including Autotech HD springs (no cam) )> Intake manifold (bolts & gaskets included)> Throttle body> Air flow meter> BMW Large Air flow meter> G60 Valve cover> Two front fenders (16V black)> Rear hatch (16V black)> Hood (16V black)> AC condensor> AC compressor> Black with Red Stipe Dash> Other assorted goodies that I need to gather together in my basement!
brandon002
Re: (brandon002)
Post by brandon002 » Thu Dec 02, 2004 3:46 pm
Found some pics from the previous owner.. http://public.fotki.com/bouncy...ti_8v/
Grip Driver
Re: (brandon002)
Post by Grip Driver » Thu Dec 02, 2004 3:58 pm
very nice, I'm jealous hopefully no surprises with this one
brandon002
Re: (Driftin GTI)
Post by brandon002 » Thu Dec 02, 2004 4:24 pm
Judging by the 10K dollars or so worth of receipts I highly doubt there will be any surprises. I drove it back from Youngstown Ohio last night without so much as a hiccup out of the car. Drove like a champ the entire time. No oil leaks or anything.
Jettaprep
Re: (brandon002)
Post by Jettaprep » Thu Dec 02, 2004 4:45 pm
looking awsome!!!
ryang60
Re: (Jettaprep)
Post by ryang60 » Thu Dec 02, 2004 5:58 pm
It's suuuhweet! Now, go find me one just like it in as good of condition. (Maybe in black.) Call me when you find one.
golf97
Re: (brandon002)
Post by golf97 » Thu Dec 02, 2004 9:51 pm
good luck with this one....very nice
detour1999
Post by detour1999 » Thu Dec 02, 2004 10:20 pm
nice to see you back in a mk2.(You have a good track record with mk2's from ohio )congrats!-d.
redfred1969
Re: I am again satisfied... (detour1999)
Post by redfred1969 » Fri Dec 03, 2004 6:14 am
Now that is a list of replacement/upgrade parts!I can't wait to get home and see some pics. Damn IT guys are blocking that site!The MK2 bug is biting!!
brandon002
Post by brandon002 » Fri Dec 03, 2004 1:30 pm
Actually Dylan, this one is from New York. I met the guy in Ohio to swap cars. I'm loving this car. I have never driven an MKII GTI before, what a driver's car this thing is. You can toss it around corners like nobody's business. I can't stop hooking corners at outrageous speeds.
detour1999
Post by detour1999 » Fri Dec 03, 2004 2:05 pm
new pics?-d.
brandon002
Post by brandon002 » Fri Dec 03, 2004 4:19 pm
Didn't get a chance to wash her up today. Maybe tomorrow.
Strictly Gravy
Re: (brandon002)
Post by Strictly Gravy » Mon Dec 06, 2004 9:57 pm
What exactly are g60 fender flares? Sweet car btw. If i was to get another vw, id go with an Mk2. But alas, the orgasmic rumble of 8 cylinders with straight pipes awaits the gravy.......
vwmann1
Re: (Strictly Gravy)
Post by vwmann1 » Tue Dec 07, 2004 6:28 am
They are called G60 because they have g60 molded into the back
detour1999
Re: (vwmann1)
Post by detour1999 » Tue Dec 07, 2004 8:19 am
vwmann1 wrote: They are called G60 because they have g60 molded into the back
And because they came on the G60 golf over the pond. They are the wider fender flares originally found on 91 & 92 16v GTi's in the US.And they break down a lot if they're not taken care of... hence their name -d.
brandon002
Post by brandon002 » Tue Dec 07, 2004 12:42 pm
The fronts are a lot wider then the stock flares, the rears are the same I believe.
detour1999
Re: (brandon002)
Post by detour1999 » Tue Dec 07, 2004 1:08 pm
rears are technically different, but sucha small difference that you can't really notice. Fronts, as you said, are significantly wider than "normal" big bumper flares.-d.
dubfanatic
Re: (detour1999)
Post by dubfanatic » Tue Dec 07, 2004 7:39 pm
91-92 GTI 16v flares = G60 flares 8v big bump jetta, 16v big bump jetta GLI, & 8v GTI 90-92 = 8v flaresNice GTI, have fun with it. I love my mkII.
ryang60
Re: (detour1999)
Post by ryang60 » Thu Dec 09, 2004 4:39 pm
This is all sorts of off topic... but:
detour1999 wrote:And because they came on the G60 golf over the pond.
AKA - Rallye Golf? If so... why was I thinking the compressor was smaller in those... a 'g40'? (Your right, i googled it... im just wonder where this g40 idea came from)
detour1999
Re: (ryang60)
Post by detour1999 » Thu Dec 09, 2004 9:52 pm
ryang60 wrote:AKA - Rallye Golf?
No... the rallye had totally different body panels (box fenders)... the G60 flares were on the "regular" g60 golfs.The rallye also had the same g60 engine, along with it's yummy AWD sytem.the g40 afaik only came in the Polo.Brandon, the weather's been nice, why no pics?Oh, and people, buy this man's extra head.-d.
Re: (detour1999)
Post by Sir Revalot » Sat Dec 11, 2004 5:40 pm
Nice MkII dub Driver 4 ever
brandon002
Re: (detour1999)
Post by brandon002 » Sun Dec 12, 2004 4:15 pm
My memory stick on my digital camera is full and I haven't had time to upload them to the PC to make room for new pics. I'll get around to it soon. Pics will come this week.
fein1
Re: (brandon002)
Post by fein1 » Thu Dec 16, 2004 8:46 pm
Pics punk!!! See you in afew days.
