IL Emissions testing!
Having problems with your Volkswagen or Audi? Have questions in regards to upgrades and tuning? This is the place to ask your questions.
Randum
Post by Randum » Thu Nov 04, 2010 2:08 pm
To me, emissions meant; No CEL = Pass, CEL = Fail! Come again!
I've been doing some reading up on the non-dp/stage 2, and other exhaust modifications...
In Illinois, has anyone run into a scenario where they have no CEL but fail because of the CAT "readiness" setting?
I have some time, but thought it would be worth investigating....
Grip Driver
Re: IL Emissions testing!
Post by Grip Driver » Thu Nov 04, 2010 2:28 pm
yes, you will fail if eveything is not in "ready" status
Cheers,
Conrad
The Autobarn City VW
12 Golf TDI
10 Sportwagen TDI
90 Eunos Roadster
Dybz
Post by Dybz » Thu Nov 04, 2010 5:30 pm
how does it work with APR? i thought their program tricked the ECU into thinking everything is running properly. someone on golfmkv recently mentioned that it's not the case, and you will in fact fail if you are stage II?
Hybrid > Diesel
Grip Driver
Post by Grip Driver » Thu Nov 04, 2010 5:57 pm
I've had one car that I had to flash back to stock because he would not set readiness, that was the only one I know if
Cheers,
Conrad
12 Golf TDI
10 Sportwagen TDI
90 Eunos Roadster
Randum
Post by Randum » Thu Nov 04, 2010 6:42 pm
Interesting- if you have a stock setting on the APR tune though? Or could you simply be sure you have a cat and test it while in stock mode?
brus6286
Post by brus6286 » Fri Nov 05, 2010 10:55 am
I was actually reading a thread over at the 'Tex mentioning someone who failed due to them being "chipped". What happens is when you take your car to the emissions and they scan test it, there are no CEL's = ready, the scanner then resets your ecu and also all your readiness codes should be at "n/a" or "fail" since you just reset your ecu and should require a certain amount of engine run cycles. So when the Emissions scanner, scans your ecu, resets and your "chipped" car has the "force readiness" codes it will fail.
I'll look for the thread...
EDIT! FOUND IT... maybe something related to this?
http://forums.vwvortex.com/showthread.p ... t=emission
g60_corrado_91
Post by g60_corrado_91 » Sun Nov 07, 2010 5:56 pm
Andrey, I remember that. Maybe St. Louis emissions testing requires the O2 sniffers at the exhaust tips and that's why they failed? From what Conrad just said, with that one exception, as long as the readiness status is correct.
gasket_case
Post by gasket_case » Tue Jan 04, 2011 2:10 am
Interesting that I just saw this now...I just went through a lot of stress with my A3 because of this. And by the way, you don't fail per se, but the car gets "rejected" and the sheet will say something like "monitors not ready" or something similar, referring to the various sensors.
My car is stage 2 with a full apr exhaust and after clearing a CEL for some random thing I can't even remember, I just drove it EVERYWHERE to give the sensors time to reset themselves, which they did and I passed on the third try.
A friend once asked why I never get manicures. I told her "I always break my nails when I work on my car anyway and I could save that money for a bigger turbo." Needless to say she doesn't ask me to go get my nails done anymore.
2006 Audi A3 2.0T
2003 BMW F650GSP
Randum
Post by Randum » Tue Jan 04, 2011 10:44 am
Thats good to know, in another three years when I have to test, I'll drive around for a while, see if it passes, if not, I'll have to put the stock exhaust back on there...ugh.
Post by KO-R32 » Tue Jan 04, 2011 11:21 am
gasket_case wrote: My car is stage 2 with a full apr exhaust and after clearing a CEL for some random thing I can't even remember, I just drove it EVERYWHERE to give the sensors time to reset themselves, which they did and I passed on the third try.
Yeah I once made the mistake of checking for codes & clearing prior to getting tested. Not ready = can't pass. After a bit driving (including highway speeds) things were ready.
Potentially more worrisome for Stage 2 and up is the experience of a vortex poster (from the link above) who seems to be saying that the DMV in his home state can also check for "forced readiness" which could be interpreted as a sign of circumvention (e.g. you pass, but then they clear readiness and find one block is already ready and therefore suspect). I don't think this is much of a worry though here in IL. Other states are much more serious about their inspections and much less in debt.
screwball wrote:Seems the state's getting smarter and I'm to try a private inspection station to see if I can get this heap to pass state inspection. I was dinked for all the forced blocks that Uni sets in the readiness to pass as "unsupported" by the DMV which raises a red flag and doesn't allow me to pass readiness for the inspection.<p>I would imagine that Eurodyne and anyone w/ a custom tune will be dealt the same fate.
Post by Sir Revalot » Wed Jan 12, 2011 7:49 am
My 97 VR just passed last Friday and I'm good for another 2yrs :thumbup:
That same week on Monday we cleared the CEL using cheap scanner from Auto Zone, i drove the car for maybe 20miles after that and parked it, Friday morning went in for the test and passed with flying colors.
When Jason from M1 used to clear my codes using VAGCOM in the past I would drive from his shop in Glenview to Elk Grove Village @ quarter throttle and pass everytime.
Dubmekanik
Post by Dubmekanik » Wed Jan 12, 2011 11:23 pm
I have personally had at least 2 cars pass emissions with 1 and another with 2 readiness codes incomplete. If there is a problem creating readiness, it is definitely on the software provider, and should be resolved. I have also run into a few unique situations where plugs were swapped between adjacent components (another shop) and the car would not set readiness, but also did not show a cel...
Mobile One Inc VW and Audi performance tuning 847.724.7097
/ General maintenance / Mig+ Tig welding / Standalone eng. management / 2WD Dyno on site
Authorized Unitronic Dealer For Illinois
https://www.facebook.com/MobileOneInc" onclick="window.open(this.href);return false;
Post by Sir Revalot » Thu Jan 13, 2011 3:52 pm
I forgot to add that it was a bad MAF on my car back in the day, no CEL unless I would hit over 5K rpm's..... Once a fresher MAF was swapped in no more code :thumbup:
That made me happy cuz it's hard to keep my VR under 5k rpm's :whistle:
Post by kakakaoo » Thu Aug 09, 2018 8:15 pm
adidas nmd shoes
hermens bags
uggs canada
nike free 4.0
cleveland indians jerseys
hermes handbags
minnesota twins jerseys
colorado rockies jerseys
coach factorty outlet
los angeles angels jerseys
nike air max 95
fred perry
chicago white sox jerseys
cristiano ronaldo jerseys
ecco shoes for men
houston astros jerseys
mulberry outlet
nike air max 87
air max 2019
cheap mlb jerseys china
nike air max shoes
converse outlet store
philipp plein shirt
hermes birkin
supreme new york
los angeles dodgers jerseys
abercrombie and fitch
arizona diamondbacks jerseys
cincinnati reds jerseys
tory burch outlet
kyrie 4 shoes
salomon shoes
coach outlet store online clearances
atlanta braves jerseys
new york mets jerseys
louis vuitton
air max 2017
louis vuitton
tiffany and co
ultra boost
underarmour shoes
asics shoes
tory burch outlet
birkenstocks
air max 2018
tiffany and co
toronto blue jays jerseys
red bottoms shoes
adidas campus
oakland athletics jerseys
pandora jewelry official site
san diego padres jerseys
polo outlet store
pg 2
baltimore orioles jerseys
ray ban sunglasses discount
jordan retro 11
birkenstock
seattle mariners jerseys
pittsburgh pirates jerseys
florida marlins jerseys
air max 2018
replica watches
cartier outlet
nike air max outlet
adidas
ralph lauren sale clearance
kansas city royals jerseys
dr martens outlet
milwaukee brewers jerseys
tory burch outlet
tampa bay devil rays jerseys
pandora
texas rangers jersey
nike air more money
hermes handbags
kobe bryant shoes
pandora store
cheap nike air max
hermes handbags
cheap ray bans
coach
gucci outlet
yeezy 350 boost
180810yueqin
Post by kakakaoo » Fri Aug 10, 2018 1:16 pm
Post by kakakaoo » Mon Oct 08, 2018 9:28 pm
chenlina
Post by chenlina » Sun Nov 11, 2018 7:49 pm
chenlina20181112
cheap rolex watches
giuseppe zanotti
cheap michael kors bags
coach handbags
ugg australia
pelikan pens
jordan pas cher
herve leger
the north face outlet
paul george shoes
ugg for women
coach handbags
mk purse
scarpe mbt
mac makeup
ugg clearance
lebron james jersey
supreme pas cher
parajumpers jackets
lululemon sale
nike lunarglide
ambassador 10
nike air max plus
mishka clothing
under armour shoes
nike blazer
pandora jewelry canada
ugg sale
air jordan
breguet watches
tiffany jewelry
nike socks
snapback hats
barcelona jersey
michael kors taschen
lee jeans
soccer jerseys
ugg australia
jordan 11
the north face jackets
sophia webster
air jordan 5
tory burch bags
michael kors handbags sale
polo shirts
kd 10
camisetas de fútbol
[url=http://www.trikotsgünstig.de]trikots günstig[/url]
ugg boots for men
christian dior handbags
breitling watches
ugg sale
vans old skool
nike sb
juicy couture handbags
adidas jeremy scott
nike blazer
curry shoes
ugg slippers
wedding shoes
miu miu sunglasses
tods shoes
soldier 10
tommy hilfiger shirts
ronaldo jersey
ナイキ スニーカー
ferragamo
soldier 9
ugg for men
maglia calcio
maillot de foot pas cher
russell westbrook jersey
tiffany bracelet
nike trainers
lebron 15
vendita maglie calcio
timberland outlet online
victoria's secret outlet
adidas wings
baby uggs
saint laurent sunglasses
van cleef & arpels
true religion
nike hyperdunk
mcm handbags
nfl jersey
womens ugg boots
soccer jerseys
manolo blahnik
under armour shoes
snapback hats
tory burch shoes
nine west shoes
chaussures christian louboutin
marc jacobs bags
fjallraven kanken
air jordan 1
russell westbrook shoes
celine handbags
police sunglasses
nike flip-flops
canada goose canada
baseball bats
versace sunglasses
coach handbags
x-large clothing
new balance
stussy
ray ban sunglasses cheap
hermes kelly bag
soccer jerseys
canada goose down jackets
camisetas de fútbol
versace handbags
saucony running shoes
lebron 13
moose knuckles jackets
true religion
kyrie 3
balenciaga triple s
north face backpacks
nike vapormax
kate spade purse
dolce and gabbana
hermes belt
puma slides
yoga pants
hogan outlet
jordan xx9
fila shoes
jordan
y-3 shoes
north face outlet online
nike flight bonafide
tom brady jersey
lululemon
air jordan 8
tiffany jewelry
lebron 15
versace clothing
hundreds clothing
lebron soldier 11
huarache
nicholas kirkwood
mizuno running shoes
harden vol 2
tom ford sunglasses
beats headphones
true religion
air jordan
manchester united jersey
canada goose canada
ray ban sunglasses for women
stan smith
michael kors purse
air jordan
cheap jerseys
maui jim sunglasses
shoe carnival
puma fenty
pasotti ombrelli
adidas slides
prada sunglasses
ugg for kids
jordan 14
kd 8
hollister clothing
vibram shoes
nike presto
nike tn
hermes
adidas yeezy 350 boost
kyrie 2
ralph lauren jeans
air jordan 12
adidas flip flops
nike epic react
ysl makeup
air jordan 6
marc jacobs handbags
soccer jersey
coach outlet sale
mikimoto jewelry
woolrich jackets
persol sunglasses
stephen curry jersey
adidas football boots
tory burch shoes
omega watches
prada
ferragamo belt
levi's jeans
fussball trikots
visconti pens
linda farrow sunglasses
bottega veneta handbags
onitsuka tiger
undefeated clothing
teva sandals
nike shoes for women
manolo blahnik
ugg store
flipflops
russell wilson jersey
coach handbags
marcelo burlon
superdry clothing
kobe 11
maillot de foot
jordan pas cher
tiffany jewelry
cheap replica watches
alexander mcqueen
arcteryx sale
air jordan 4
lebron 14
ugg sale
flip-flops
nike tennis
omega watches
ugg boots sale
ugg sale
yeezy 500
nike mercurial
supreme hoodie
vetements clothing
tory burch
nike sb
sac longchamp
oakley sunglasses cheap
burberry sale
bvlgari jewelry
mcm bagsk
spalding basketball
designer belts
nike roshe
true religion
ugg sale
cheap supra shoes
nike roshe
monster headphones
air jordan 3
true religion
nike air max 270
chenlina20181112
