It is currently Mon Feb 19, 2018 10:40 pm
Reply to topic  [ 8 posts ]
Good floor jack/stands
Just looking for any recommendations for some nice jack stands/jack for use in my garage. Nothing too crazy, but something that will be reliable, built well etc. (say if I want to install a rear sway)
I see autozone has a few options, but rather ask around before buying blindly...
Thu Oct 11, 2012 2:27 pm
Profile YIM WWW
If you're installing a rear sway bar I recommend getting ramps. You'll need to have the rear suspension compressed to easily install the end links on the rear sway.
If you need to borrow a pair let me know.
Thu Oct 11, 2012 8:50 pm
Or you can just rotate the sway bar and connect the links lol
:newhere:
Fri Oct 12, 2012 8:23 am
Good to know - I might just pick up a pair assuming I'd use them in the future.
Thanks, if I need them I'll shoot a PM over, just looking at the ton of options for rear sways now...
Fri Oct 12, 2012 9:35 am
Profile YIM WWW
ramps ftw. a lot easier than jacking the car up if all you need is to get under it. that stuff is cheap though, get a pair of jacks, pair of ramps, and good jack. pepboys/autozone stuff is fine.
Hybrid > Diesel
Fri Oct 12, 2012 10:49 am
I have a mega-super-heavy 3 ton Craftsman jack (thing weighs around 80lbs), which I use for garage work, and I have a small Pittsburgh (Harbor Freight) aluminum race jack for autocrosses, it's very lightweight and easy to transport. But if I'm doing oil changes, etc, I use ramps, I've had a set of Rhino Ramps for years, and I really like them.
My ratcheting jack stands are MVP or something, I think they were Walmart specials, but they work well.
Nothing special, if it gets the car off the ground and keeps it there, you're good. Features manufacturers promote are fast-lift (usually at the expense of load, however), lightweight (for race jacks, sure, but if it'll be a garage jack, who cares), and dumb stuff like LEDs in the jack pad.
Just be sure to ALWAYS use jack stands. I've heard plenty of stories of jacks failing while people are under the vehicle. They don't end well.
Drag racing is for fast cars, autocrossing is for fast drivers.
http://www.madisonsportscarclub.com
http://www.scirocco.org
2 cars, 9 cylinders, 36 valves
Fri Oct 12, 2012 4:38 pm
Ramps ftw unless you need wheels off.
I have 2 cheap trolley jacks and 4 Jack stands. the trolley jacks lift a bit higher than cheap floor jacks.
Protip: if your car is too low for your otherwise fine jack, keep a couple 2x6s around, and drive up on them.
Sun Nov 11, 2012 3:49 pm
I just picked up one of these at Harbor Freight.
http://www.harborfreight.com/automotive-motorcycle/floor-jacks/2-ton-low-profile-heavy-duty-floor-jack-rapid-pump-68050.html
$130 plus tax. 2-5/8" low profile. 23-3/4" max height. Has a good length arm so it reaches way under. 2 ton. Solid & stable.
The only drawback is this thing is 100 lbs, so it's a garage jack, not a toss in the trunk jack.
They also had a selection of jack stands and aluminum racing jacks.
Sun Nov 11, 2012 11:20 pm
