Chicago Volkswagen Organization
http://forums.chicagovw.org/
code PO501 on 96 vr6
http://forums.chicagovw.org/viewtopic.php?f=13&t=5089
Page 1 of 1
Author:  golf97 [ Mon Aug 29, 2005 10:35 am ]
Post subject:  code PO501 on 96 vr6
Vehicle Speed Sensor Range/Performance ??? I tried to find it on the vortex without any luck..any idea where to look or what has to be done to clear this code ???
Author:  Grip Driver [ Mon Aug 29, 2005 11:45 am ]
Post subject:  Re: code PO501 on 96 vr6 (golf97)
Have you noticed the speedometer going goofy? If so, either the sensor is shot or the wiring to it.
Author:  eazeonmahjetta [ Mon Aug 29, 2005 6:05 pm ]
Post subject:  Re: code PO501 on 96 vr6 (Driftin GTI)
you can easily check both with a DMM, the wiring (while disconected go from each pin the the terminal at the ECU or you can just test the AC output voltage by back probing it or using a scanner...and if you have no clue as to what i'm talking about... you can give either VFC Engineering (<---where i work ) or mobile one a call.
Author:  Weakness [ Mon Aug 29, 2005 7:04 pm ]
Where is this code from? That isn't a VAG-COM code that I have seen. Has anyone (like Doug from VFC) scanned it?
Author:  golf97 [ Mon Aug 29, 2005 7:09 pm ]
Post subject:  Re: code PO501 on 96 vr6 (Weakness)
I scanned the car with the OBDtool.com....
Author:  Weakness [ Mon Aug 29, 2005 7:10 pm ]
Come out ot cruise night on Saturday night and I'll bring my VAG-COM and we'll see what's going on.
Author:  golf97 [ Tue Aug 30, 2005 9:20 pm ]
Post subject:  Re: code PO501 on 96 vr6 (BLOWIN SMOKE)
like Conrad questioned the speedometer is working good not goofy...This car also had the low signal from the MAF....I cleared both and we are just waiting for them just to come back he has had the car driving two days and has not got them back yet so we will see in the next couple of days........will keep it updated
Author:  Kamilla [ Mon Jan 11, 2016 10:47 am ]
Thank you for posting this information!)
Page 1 of 1 All times are UTC - 6 hours [ DST ]
http://www.phpbb.com/
