1995 GMC Vandura 2500 conversion van - $3000
Have stuff laying around the house? Too lazy to list it on Ebay? Try your luck here. No Ebay auctions please. All auctions will be deleted without notice.
FVGNGN 1
Post by FVGNGN 1 » Fri Mar 13, 2009 6:44 am
I am starting to want a bigger tow vehicle, so I can get a bigger trailer down the road. So the current one has to go.I bought it 4.5 years ago with 132k miles on it.It now has 152k miles on it. That includes some driving vacations (Canada, Wisconsin, etc.) without a trailer, and some commuting when I was doing the 16v swap in the old GTI. Probably sees about 2-3k miles of towing each year.Things I have done:new exhaust in 2005new alternator in 2005new drag link in 2005Bilstein front shocks in 2005 (has air shocks in the back)new water pump in 2006new brakes in 2007new AC compressor in 2008 (AC works, but there is a slow leak now)new tires in 2006oil every 3ktrans fluid at 132k, planned to do it again this yearThings it needs:lower ball joints in the front suspension.It is not a beauty queen, but is presentable and super functional. We use it to take the family, crew and race car to the race track, and sometimes sleep in it - it has a fold down rear couch. Seating for 7, rear AC.With the air shocks it tows our 2 axle race trailer easily.The motor is a TBI (throttle body injected) 5.7 (aka 350) V8. Something like 220hp, but well over 300 lb-ft of torque. The rear axle is a taller ratio, which makes it easy to tow in 3rd rather than 4th. This makes the towing much easier on the trans as it does not shift around between 3 and 4. It does have the factory towing package, including an auxiliary trans cooler, 2" reciever hitch, and is wired with a 7 pin trailer connector with brake controller.16 valves of towing power for sale!I also have a 16' open trailer with 2 axles and brakes on both axles that can be had if you need a complete car transport package.
Re: 1995 GMC Vandura 2500 conversion van - $3000
Post by valladar » Thu Jun 28, 2018 12:25 am
zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990zo13990
zo13990zo13990
Post by valladar » Tue Sep 18, 2018 11:01 pm
Post by kakakaoo » Mon Oct 08, 2018 11:31 pm
Post by kakakaoo » Mon Oct 08, 2018 11:32 pm
