Autocross #3 RESULTS
The place to discuss past, present and future CVO Motorsport events.
JR32
Post by JR32 » Sun Jun 10, 2012 7:30 pm
:cool: Click Here
Let me know if there are any spelling errors or car corrections.
the manager
Re: Autocross #3 RESULTS
Post by the manager » Mon Jun 11, 2012 8:13 am
Thanks for all the runs on Sunday. It was a challenging, yet interesting course design.
Thanks for all the hard work putting this together.
imarcr2
Post by imarcr2 » Mon Jun 11, 2012 9:21 am
I agree with the manager, great course, efficient and friendly coords
2012 GTI
95 Miata
Grip Driver
Post by Grip Driver » Mon Jun 11, 2012 11:43 am
Great event, I had a great time, thanks for your hard work :) I still have some work to do on the Mazda as I found out :)
Cheers,
Conrad
The Autobarn City VW
12 Golf TDI
10 Sportwagen TDI
90 Eunos Roadster
Silberlowe
Post by Silberlowe » Mon Jun 11, 2012 6:16 pm
Grip Driver wrote:Great event, I had a great time, thanks for your hard work :) I still have some work to do on the Mazda as I found out :)
That is the reason we are out there dodging those cones, we always will find a way to improve ourselves and our cars one way or the other.
I also had a great time .....
Erik J.
1998 MK III GLX
JR32
Post by JR32 » Mon Jun 11, 2012 6:46 pm
Hah I found out I need a new tire pressure gauge...when I went to fill up my tires after my last run I had 25psi in them...not 32 like the gauge was showing. Which also explains why I couldn't get my time down after dropping my tire pressure to what I thought was ~32
Post by got desl? » Mon Jun 11, 2012 7:46 pm
I was curious to know why the lower tire pressures on Sunday improved times vs the usual higher pressures? Good layout without a doubt, was just having an off day this time around. Hopefully Tire Rack will go better for me :thumbup:
g60_corrado_91
Post by g60_corrado_91 » Tue Jun 12, 2012 1:07 pm
Damn Jake.
Dawid, there's a fine line with tire pressures, plus every tire is different. Add in the cars weight, setup, driving style, and the surface conditions themselves, and you've got a ton of variables. With that said, I've always had my fastest times by lowering the fronts to 31-32, and keeping the rears at 42-45psi. Even in Shelly's TT, I ended up lowering the fronts I about 31 and pumping the rears to 40-42 IIRC. But, I like a little rotation. And I tend to push the hell out of cars. If you're a smooth driver, higher pressures up front probably do work out.
Silberlowe
Post by Silberlowe » Tue Jun 12, 2012 5:54 pm
Damn Jake.
Dawid, there's a fine line with tire pressures, plus every tire is different. Add in the cars weight, setup, driving style, and the surface conditions themselves, and you've got a ton of variables. With that said, I've always had my fastest times by lowering the fronts to 31-32, and keeping the rears at 42-45psi. Even in Shelly's TT, I ended up lowering the fronts I about 31 and pumping the rears to 40-42 IIRC. But, I like a little rotation. And I tend to push the hell out of cars. If you're a smooth driver, higher pressures up front probably do work out.[/quote]
Then You and I have the same driving style in totally different cars, last Sunday I started the day w/40PSI all arround on cold tires, but after the tires got warmer as well as the track did to, I had to drop the fronts down to 37 PSI and the rears down from 43.5 to 40PSI a pound or so at a time. In fact, the layout of the track played the main roll, it had more hard right turns than left ones the I even adventured to drop the pressure down on the rear right down to 35PSI and that did improved my times.
I spend pretty much the first hit trying to find a set up I felt confortable trought the slow part of the course and the slalom, I know I could improve alot more since I was kindda understeering on the long sweeper after the slalom heading to the tech tent, but then again, it could be just me since I'm new to all this HEHEHEHE!! :D
Erik J.
1998 MK III GLX
Post by KO-R32 » Tue Jun 12, 2012 9:31 pm
Yeah it looks a little low :whistle:
A big thanks to Jake, Shelly, Dmytro, JR, Chris, Sarah, Dawid and all for great day. Have fun at the Tire Rack!!!!
Twitch9mm
Post by Twitch9mm » Wed Jun 13, 2012 5:53 am
Great course layout Jake, the mix of fast and technical was awesome! Can't wait for the rack. Also, Damn you Karl with your driver mod :laugh: but good running for sure.
GIAC K04 High-Output Tune, AWE K04 Turbo, S3 Injectors, Techtonics Tuning Full SS Exhaust, BSH True Seal intake, BSH revamp kit, H&R Premium Performance Coils-overs, Autotech HPFP, Audi RS4 140bar Fuel Pressure Regulator, Forge Twintercooler, South Bend Stg2 Street Clutch/Single Mass Flywheel, ASA GT5s wrapped with Dunlop Direzza Star specs
Post by valladar » Fri Jun 29, 2018 9:44 am
zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192zo15192
zo15192zo15192
