Autocrosses with other clubs
Autox 2
Re: (r0nd3L)
Post by Autox 2 » Fri Oct 24, 2008 5:07 pm
The awards are on Nov 22nd.All you need are good tires, just buy some Hoosier A6's and a jack.
r0nd3L
Re: (toneesvr6)
Post by r0nd3L » Fri Oct 24, 2008 5:19 pm
toneesvr6 wrote: The awards are on Nov 22nd.All you need are good tires, just buy some Hoosier A6's and a jack.
Yea, except I'm racing in STU = street tire class
Autox 2
Re: (r0nd3L)
Post by Autox 2 » Sat Oct 25, 2008 5:03 am
r0nd3L wrote:Yea, except I'm racing in STU = street tire class
For now.........
r0nd3L
Re: (toneesvr6)
Post by r0nd3L » Sun Oct 26, 2008 10:17 am
toneesvr6 wrote: For now.........
Haha for now indeed.....
g60_corrado_91
Re: (r0nd3L)
Post by g60_corrado_91 » Sun Oct 26, 2008 11:17 am
So is the season pretty much over?
r0nd3L
Re: (g60_corrado_91)
Post by r0nd3L » Sun Oct 26, 2008 11:30 am
g60_corrado_91 wrote:So is the season pretty much over?
Yup
g60_corrado_91
Re: (r0nd3L)
Post by g60_corrado_91 » Sun Oct 26, 2008 1:21 pm
Yeah, supposed to snow tonight.
Post by KO-R32 » Sun Oct 26, 2008 2:21 pm
No way I'm putting snow tires on yet
g60_corrado_91
Re: (KO-R32)
Post by g60_corrado_91 » Sun Oct 26, 2008 3:04 pm
Me neither. I've got to get them balanced this week.
Autox 2
Post by Autox 2 » Mon Oct 27, 2008 4:15 am
There are a couple events left, and PCCA at Maywood, sometime in November. But I'm done for the year.
g60_corrado_91
Re: (toneesvr6)
Post by g60_corrado_91 » Mon Oct 27, 2008 8:18 pm
Different type of event, but I may head over to Byron on Sunday if the weather cooperates. My car with the heat range cooler spark plugs, Forge DV spike fix, and fresh oil was pulling in this 35 degree weather.
r0nd3L
Post by r0nd3L » Mon Oct 27, 2008 8:40 pm
I may be going to GLD that day but not sure. Maybe Byron would be better.
Re: (r0nd3L)
Post by KO-R32 » Mon Oct 27, 2008 8:57 pm
Byron Sunday?
g60_corrado_91
Re: (KO-R32)
Post by g60_corrado_91 » Tue Oct 28, 2008 12:36 pm
Haha, come with! I'm trying to get Jake to go along as well. A few guys from my work are going as well as some guys from the Chicago Garage. For $25 it's not too bad, especially if it's really going to be 55ish degrees.
Post by KO-R32 » Tue Oct 28, 2008 1:03 pm
True. F1 finale though at 11am. . . wouldn't mind running the A4 though. Should be low 14. .
Autox 2
Post by Autox 2 » Tue Oct 28, 2008 1:20 pm
g60_corrado_91 wrote:Haha, come with! I'm trying to get Jake to go along as well. A few guys from my work are going as well as some guys from the Chicago Garage. For $25 it's not too bad, especially if it's really going to be 55ish degrees.
Do you need a helmet if you hit over 100mph? I'd like to see what I'd run.(maybe I should put the Azenis back on instead of the Kumho All-seasons) Modified by toneesvr6 at 3:47 PM 10/28/2008
r0nd3L
Re: (toneesvr6)
Post by r0nd3L » Tue Oct 28, 2008 1:21 pm
toneesvr6 wrote: Do you need a helmet if you hit over 100mph? I'd like to see what I'd run.(maybe I sould put the Azenis back on instead of the Kumho All-seasons)
Helmet for 13.99 and under.
Autox 2
Re: (r0nd3L)
Post by Autox 2 » Tue Oct 28, 2008 1:48 pm
r0nd3L wrote:Helmet for 13.99 and under.
You mean for 13.990@100.02 2.172 60'?
g60_corrado_91
Re: (toneesvr6)
Post by g60_corrado_91 » Tue Oct 28, 2008 2:00 pm
Hahaha. I'm probably going to put on my AutoX setup as well because they didn't launch too bad when I was at the Miata club in Stg 2.
Autox 2
Post by Autox 2 » Tue Oct 28, 2008 2:34 pm
g60_corrado_91 wrote:Hahaha. I'm probably going to put on my AutoX setup as well because they didn't launch too bad when I was at the Miata club in Stg 2.
That's means you babied the launch at WCMC, at SCCA I babied the launch and still spun them through 2nd. A Diff is the only way around that or slicks.
g60_corrado_91
Re: (toneesvr6)
Post by g60_corrado_91 » Tue Oct 28, 2008 3:07 pm
How did you launch? I slip the hell out of the clutch. Plus there was a right turn into the figure 8 so I only got up to say 20mph. 30 tops.
Autox 2
Post by Autox 2 » Tue Oct 28, 2008 3:10 pm
g60_corrado_91 wrote:How did you launch? I slip the hell out of the clutch. Plus there was a right turn into the figure 8 so I only got up to say 20mph. 30 tops.
Feathered the clutch till it grabbed for about 20ft, then put my foot into it. Otherwise I'd spin all the way thru 3rd like I do on the street. Modified by toneesvr6 at 6:14 PM 10/28/2008
Autox 2
Post by Autox 2 » Tue Oct 28, 2008 4:19 pm
And people wonder why I go to the Joliet events, 20-30mph? Through the back turnaround, infront and after it it's 55-70mph all the way!
r0nd3L
Re: (toneesvr6)
Post by r0nd3L » Wed Oct 29, 2008 9:14 am
toneesvr6 wrote: And people wonder why I go to the Joliet events, 20-30mph? Through the back turnaround, infront and after it it's 55-70mph all the way!
High speed FTW.
MarioM
Re: (r0nd3L)
Post by MarioM » Wed Oct 29, 2008 2:08 pm
Why do you kids keep calling Joliet high speed. It's low-medium speed. High speed would be Solo I.
