MKIII Cabrio
SLiMeX
MKIII Cabrio
Post by SLiMeX » Sat Jan 07, 2012 12:14 am
This past August, a coworker of mine approached me asking for help selling her car since I am the resident gearhead.
She hadn't driven it in about a month then, and it definitely needed some work to be a reliable daily.
I checked out the car, and we put it up for sale everywhere we could find, but there were no bites at all.
Fast forward to about three weeks ago, she asked if I would buy it.
I lowballed her, and to my surprise, she accepted my offer and I bought a (pretty much stock) '95 Cabrio with 102k and a 5-speed.
The car hadn't even been started in about six months, so the battery was dead and she had to be jumped, but she started right up and with the help of a friend, I relocated the car from Logan Square in Chicago to Downers Grove. We stopped to wash her along the way because there was so much debris and dirt built up, I had to wash it away:
I'm new to the MKIII world, so I will have a lot of questions and parts needed.
Are there any resident MKIII gurus?
Chris
MKV Rabbit
MKIII Cabrio
JoseGtiPerez
Re: MKIII Cabrio
Post by JoseGtiPerez » Sat Jan 07, 2012 12:34 am
i own a 96 2.0L 5speed cabrio 37k about to turn 38k miles on it original miles no bs with alot of work done to it kept on sythetic oil since i got it and im looking to sell it since i got me mk4 gti with a bigger engine.
Re: MKIII Cabrio
Post by got desl? » Sat Jan 07, 2012 7:54 am
I know Dmytro and Jake have a lot of knowledge with MKIII. Hit them up with any questions they'll be the quickest to let you know probably.
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Sat Jan 07, 2012 10:02 am
Chris
MKV Rabbit
MKIII Cabrio
Re: MKIII Cabrio
Post by Sir Revalot » Sun Jan 08, 2012 3:26 pm
Very nice buy dude!!
You can start with chip upgrade and crank pulley, it will really wake up that 2.slow.
Mine had a K&N drop in filter, autotech chip and Eurosport light weight pulley and put down 121whp and 134wtq and that was with way more miles on it.
I'm selling my crank pulley, see my post on classifieds.
My Golf just flipped 160k and does not leak or burn a drop of oil and you know how I drive my cars.
How's the under carriage on your cabrio??
MKIIIs tend to rust away from the bottom up if not looked after in that area.
Get some racelands for it, set of BBS wheels and will have one cool ride.
Re: MKIII Cabrio
Post by KO-R32 » Sun Jan 08, 2012 9:50 pm
Nice Chris. Looks straight and is even shinny! Love the suds pic!
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Sun Jan 08, 2012 11:37 pm
Sir Revalot wrote:You can start with chip upgrade and crank pulley, it will really wake up that 2.slow.
Thanks for all the positive feedback, everyone!
I have a laundry list of replacement parts that need to be fixed before I start thinking about performance.
The bottom of the car isn't rusted, but both front fenders are rusting behind the wheel. No one would have replacement fenders, would they?
Chris
MKV Rabbit
MKIII Cabrio
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Tue Jan 10, 2012 10:52 am
I had a giftcard to an online parts supplier, bought a bunch of replacement parts for a tune-up.
Let the amassing of parts begin!
Chris
MKV Rabbit
MKIII Cabrio
Re: MKIII Cabrio
Post by got desl? » Tue Jan 10, 2012 11:07 am
That's going to be a fun and awesome project!! Best of luck, ever need help wrenching let me know :thumbup:
Re: MKIII Cabrio
Post by Sir Revalot » Tue Jan 10, 2012 12:22 pm
SLiMeX wrote:I had a giftcard to an online parts supplier, bought a bunch of replacement parts for a tune-up.
I hope that the tune up includes the distributor!!
Doing the spark plugs and wires is fun, you need to remove the intake manifold so you will need or should replace the gasket between upper and lower intakes. Also a good time to inspect the intake ports and clean them up from carbon build up, check the throttle body too.
Since you will have the intake off the engine inspect the valve cover gasket, if it's wet then you should replace that too and don't forget to look at the vacuum lines, those tend to rot away after a while.
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Tue Jan 10, 2012 1:14 pm
Sir Revalot wrote:I hope that the tune up includes the distributor!!
The giftcard was only for $100, but I got the following parts:
-Distributor Cap
-Distributor Rotor
-Spark Plugs
-Fuel Filter
-Oil Pan (the Cabrio's was rusty and dented)
-Oil Pan Gasket
-Oil Pan Nut
Chris
MKV Rabbit
MKIII Cabrio
Re: MKIII Cabrio
Post by Sir Revalot » Tue Jan 10, 2012 6:11 pm
-Distributor Cap
-Distributor Rotor
-Spark Plugs
-Fuel Filter
-Oil Pan Gasket
-Oil Pan Nut
:thumbup: :thumbup:
Just inspect the gasket that is between the upper and lower intakes, if there are no crack in it you should be ok.
You should joey mod the bumpers..... :whistle: if you do let me know I will tell you which paint to buy.
JoseGtiPerez
Re: MKIII Cabrio
Post by JoseGtiPerez » Tue Jan 10, 2012 10:26 pm
u dont need to take the intake off i have the same car and i didnt have too
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Tue Jan 17, 2012 2:55 pm
Does anyone have a MKIII Bentley Manual laying around that I can borrow/buy?
Chris
MKV Rabbit
MKIII Cabrio
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Tue Jan 24, 2012 9:44 pm
SLiMeX wrote:Does anyone have a MKIII Bentley Manual laying around that I can borrow/buy?
Bought my own today! :albert:
Chris
MKV Rabbit
MKIII Cabrio
Dubbin'0n15s
Re: MKIII Cabrio
Post by Dubbin'0n15s » Wed Jan 25, 2012 5:44 pm
Nice buy. What are your goals with it? You don't need to take the intake mani off for spark plugs. I would hockey puck the front and pass side engine mounts for better response and drive-ability overall(if you want cheap, otherwise invest in some bfi mounts). I would rebuild the shifter by replacing all the bushings ( makes a world of a difference). A/C delete is very simple on these things if it doesn't work. There's a whole laundry list of things you can do on mk3s. Lmk if you have questions.
:newhere:
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Wed Jan 25, 2012 10:57 pm
Dubbin'0n15s wrote:Nice buy. What are your goals with it?
First and foremost, it needs a brake system overhaul.
I'm not planning on converting it to 5-lug, but it needs new pads, rotors, drums, shoes, lines, e-brake cables, etc.
After that, I dunno. I definately want to put it on coilovers and a set of widened steelies. Does anyone have Corrado steelies?
Chris
MKV Rabbit
MKIII Cabrio
Re: MKIII Cabrio
Post by Sir Revalot » Thu Jan 26, 2012 10:48 am
God damn, when I did my tune up I was told to remove the intake!! Now I know why I don't get advise from that person.
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Thu Feb 09, 2012 11:00 pm
Today I picked up up an original shift boot and knob along with a set of OEM pedals (previous owner installed a Momo shift knob and pedals).
Chris
MKV Rabbit
MKIII Cabrio
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Wed Feb 15, 2012 9:35 pm
Obligatory rolling shot:
Chris
MKV Rabbit
MKIII Cabrio
Re: MKIII Cabrio
Post by got desl? » Thu Feb 16, 2012 7:52 am
She could use a good buffing....other than that looks solid!
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Mon Feb 20, 2012 12:50 pm
This past Saturday (2/18), I drove over to where it is being stored for now with the intention of removing the license plates and the iPass for the previous owner. It was so nice out that I decided to drive it around the vacant industrial park and snapped a few more photos to show everyone what I'm dealing with.
Needless to say, the previous owner left a lot of junk in her car:
I already cleaned out a TON of old laundry and towels along with a full set of five white plates and bowls and pint glasses (albeit from IKEA) - I put them through a dishwashing cycle and gave them to my girlfriend. I put some baking soda inside when I got it because it was smelling of something AWFUL. Luckily it has done it's job well.
Someone was asking me what wheels are on the car - they are 15" Borbet Type H's:
If anyone wants to buy them, make me an offer. They have brand new Kuhmo's and I'd be willing to trade for some 4x100 15" Corrado or 16" Beetle steelies.
Forgive me, as I am so new to the MK3 world - what headlamps are these?
At the Brat Stop meet, Jake suggested they are GTI headlamps? I guess all I want to know is if they can be taken apart and joey-modded.
Lastly - as I was cleaning out the trunk I found something that looked like a CD changer. But I tucked my phone near it and took a photo - it turned out to be a cellular transceiver! Maybe from around when it was originally purchased?
Chris
MKV Rabbit
MKIII Cabrio
mobileonevwparts
Re: MKIII Cabrio
Post by mobileonevwparts » Fri Feb 24, 2012 7:15 pm
That puppy could use a rebuilt cylinder head, a spare steering wheel, a header, an extra front strut, a set of 14" Zandvoorts... : )
Mobile One Inc VW and Audi performance tuning 847.724.7097
/ General maintenance / Mig+ Tig welding / Standalone eng. management / 2WD Dyno on site
Authorized Unitronic Dealer For Illinois
https://www.facebook.com/MobileOneInc" onclick="window.open(this.href);return false;
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Mon Mar 19, 2012 2:27 pm
Today I bought all necessary components for the brake overhaul. Pads, rotors, drums, shoes, cables, etc, etc.
All this beautiful weather is making me want to work on it sooner!
Chris
MKV Rabbit
MKIII Cabrio
SLiMeX
Re: MKIII Cabrio
Post by SLiMeX » Wed Mar 21, 2012 9:44 am
It's a shot in the dark, but does anyone have an unmolested set of Ronal Teddy Bears?
Chris
MKV Rabbit
MKIII Cabrio
