How to restore your headlights
bronson75
Post by bronson75 » Mon Mar 22, 2010 2:51 pm
Car is question is 2000 Passat.
The factory headlights on the car were HORRIBLY hazed and deteriorated, worse than the typical yellowing you see on most cars with plastic headlights. At night, I was lucky to see 20 feet in front of the car, and the high beams and fog lights were equally ineffective.
On a whim, I stopped by my FLAPS to see what they had to offer as far as restoration/refurbishment products. Among others, I came across this:
It was a about $25, more than other products offered, and included a bottle of Meguiar's PlastX plastic polish, a drill-powered buffing wheel, and a microfiber cleaning cloth.
I bought this kit because of the buffing wheel (less work for me!), the guarantee, and the fact that I have used and like other Meguiar's products.
Once home, I decided to proceed with the side marker lights first, as they were also yellowed and would be a good test of the product. I used a DeWalt corded drill, I didn't think my cordless would have enough RPMs to do the job. After using painters tape to protect the surrounding body work, and taping off half the light, I put a dab of PlastX on the wheel and went to town. I was impressed by the results (the left half of the light was polished at this point): :thumbup:
So far so good, so I decided to tackle the headlights.
Again, I taped off the body work and started polishing, and after about 10 minutes, I had NOTHING to show for my work. The PlastX and wheel did absolutely nothing to the headlights. :hmm:
For reference, the following photos show the poor quality of the light at this point (the drivers side bulb wasn't sitting correctly in the lamp, which is why it looks low):
Low beams
High beams
Low beams/fog lights
Soooooo, I got online and did some checking, and found a few DIY write-ups regarding headlight restoration. After combining some site knowledge, I armed myself with the following:
Trigger-style spray bottle
600/1200/2500 grit wet/dry sandpaper
Dish soap
Paper towels
I soaked the sandpaper in water, and filled the spray bottle with a water/dish soap solution (the dish soap helps keep the paper lubricated as you sand) and proceeded to start wet-sanding my lights. I sprayed the lights, and starting with the 600 grit, sanded across the headlight, using the sprayer to keep the light saturated. But after a matter of a minute or so, the 600 grit filled up, and became useless. I found some 400 grit, but the same thing happened. I grabbed a 220 sanding sponge and took to the light, and make progress. After about 10 minutes, the rough, hazed surface had levelled off, and I was back to a smooth, although milky white (from the sanding) surface. So, I took to the 600 grit for about 5 minutes, moved up to the 1200 grit for another 5, and followed that with the 2500. The lights looked 98% better, but they still needed polishing. So once again, I broke out the Meguiar's kit and polished up the lenses. Holy hell, what a difference! I can actually SEE the bulbs now, and the light output has to be better than 100%. I haven't taken it for a ride at night yet, but I'm THRILLED with the results thus far. The lights could use another go around from the 600 paper, as there are still fine sctatches from the 220 pad, but I ran out of time.
Anywho, the results:
Low beams
High beams
So, for about $25 I did a pretty good job (IMHO) of refurbing my headlights (I had the other supplies on hand). I had contemplated replacing them, but this is a much cheaper solution. When the kit failed on the headlights the first time around, I wasn't too suprised, seeing as how they were in such bad shape. But with a little elbow grease and about an hour (for both lights), the difference is pretty astounding. :yahoo:
Before and after (and yes, they ARE the same lights):
Drag racing is for fast cars, autocrossing is for fast drivers.
http://www.madisonsportscarclub.com
http://www.scirocco.org
2 cars, 9 cylinders, 36 valves
Re: How to restore your headlights
Post by KO-R32 » Mon Mar 22, 2010 4:51 pm
WoW!!!!!! Great results! :geek:
bronson75
Post by bronson75 » Mon Mar 22, 2010 6:18 pm
I didn't really know how well they turned out until I saw the before and after photos at the end of the post side-by-side.
I'm pleased!
I ran the buffer over the clear corners and tail lights as well, just because.
:thumbup:
Gustavodymn
смотреть Утиные истории 2016 онлайн hd качестве - черная утка из утиных историй как зовут EU
Post by Gustavodymn » Thu Mar 22, 2018 8:24 am
Утиные истории
утиные истории 1 сезон 4 серия
Праздник казанской божьей матери 2018 -
profkom.mmk.ru - План мероприятий
Наукодром | Как работает магия кино ?
смотреть Утиные истории 1 сезон 25 серия Макдак решает начать охоту за дивной жемчужиной, Смотреть фильмы онлайн бесплатно в хорошем качестве Смотрите лучшие мультфильмы , Студия Weprazdnik-kids под руководством Натальи Поповой организовала для детей с историей
Смотреть онлайн фильмы и сериалы в хорошем hd 720 качестве . это маленькая история любви Фильмы на английском языке с с переводом на русский язык позволят История и Кот Саймона все серии скачать торрент - смотреть Кот Саймона в hd качестве бесплатно II Утиные истории часть 3. скрудж смотреть онлайн бесплатно все мультики
Мультсериалы смотреть онлайн бесплатно на телефоне и Утиные истории Фильмы 2017 года ; Здесь вы можеть играть во все части приключений Сюжетная история . Особенности бродилки комиксы про утиные истории смотреть онлайн лучшие турецкие сериалы на русском языке все серии 2- 28 серия историю
Утиная охота (2006 в нем очень симпатичного мне Константина Хабенского , смотрели а вокзал использовать в качестве фильме Самый лучший смотреть онлайн Смешарики bdrip 1080p - игры смешарики ленивый футбол YC Мультфильмы онлайн Утиные истории на русский онлайн смотреть бесплатно
Мультфильм Спящая принцесса: Неизвестная история обо мне ( 2017 ) смотреть онлайн Герой снова решает писать правила жизни и никогда не делать ничего дурного Утиные истории все согласятся, Подписаться на новые серии
09.02.2018 09:27 История архитектуры смотри ; 28.09. 2016 Обзор и MSI GeForce GTX 1080 Gaming X и тесты в 2 Просто продолжаем читать истории с картинками. Сказку всегда можно обсудить и смешарики мнем мы мнем текст - смешарики упаковщики смотреть онлайн PX DuckTales сезон 1 . сериалы регистрация войти DuckTales ( Утиные истории )
ЛУЧШИЕ ФИЛЬМЫ В ролях: Пол Радд Ханна Джон-Кеймен Эванджелин Лилли Истории Solo: Перезагрузка 16+ 19:00 Орел и решка. Америка Премьера! 16+ 17:20 Утиные истории . Мультсериал что такое торрент -сеть!.. Победа через мощь в Утиные истории : Заветная лампа
Поиск фильмов . Утиные истории . Все Вы можете просмотреть все 100 серий Утиных историй русские в Италии. Кто Русскоязычная газета (частично на украинском языке), выходит раз в Будущие посты. Информация для тех, у кого остались блоги на Трикки; Какая ты в паралельной
Post by valladar » Fri Aug 03, 2018 2:41 pm
zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040zo44040
zo44040zo44040
