How to replace your Corrado SLC fog lamp lenses for $15
- dubfanatic
- CVO Forums User
Here is the contact info for the vendor to get these lenses from:http://www.rallymfg.com/V05/Phone: 305.628.2886Part number: #3183$5.48 each for JUST the lens$3.75 shipping for UP TO 5 lens! (to PA)Mail a money order (no check no cash) to:Rally Manufacturing, 5255 NW 159th St, Miami FL 33014Include part number, money order, shipping address, and Attn: Customer ServiceMany thanks to Alex, one of their fine customer service reps.First, buy the rally lights at your local Pep Boys ($34.99 I think). If your bulbs are burnt out (like mine were) you can use the bulbs from these new lights (12V 55W halogen), they fit right into the old lights.2nd, take the old cracked lens off your fog light assemblies. Be careful, it is a real pain in the a$$, I had to break off the glass, use pliers and a screw driver to get all the glass pieces off. Make sure to use thick gloves for this. Once the glass is off, try to clean off all of the old white adhesive from the frame, first with a screwdriver and then with some goo remover. 3rd, take the rally lights apart and use the lens. When you test fit you will see that it is a very close fit. There is some space left on the sides (about 1/8" on each side, and you MIGHT have to grind off some glass off the top and bottom to make it just right but it is pretty damn close. 4rth, use some black or clear(clear looks nicer IMO) silicone automotive caulk and secure the lens to the frame. Reassemble and you're done!Modified by dubfanatic at 9:13 AM 8/23/2005 Modified by dubfanatic at 9:14 AM 8/23/2005
- dubfanatic
- CVO Forums User
Re: How to replace your Corrado SLC fog lamp lenses for $15 (dubfanatic)
If you dont want to go thru the hassle of ordering witht he money order. You can pick up these lenses at Pep Boys as part of a fog lamp kit for $34.99, the lenses come right out. Modified by dubfanatic at 9:18 AM 8/23/2005
- valladar
- CVO Forums User
zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022zo46022
zo46022zo46022
zo46022zo46022
- kakakaoo
- CVO Forums User
- valladar
- CVO Forums User
