what is needed to change tranny fuild
spoolin2o
Post by spoolin2o » Fri Apr 29, 2005 10:40 pm
Hey i was wondering if any of you around have changed your trans fuild, and if so what tools are needed for the job?? i know how to do it, thats not the problem, but the drain or fill plug looked to be to large for any of the tools my friend had at his shop so i was wondering if anyone could tell me what it was and where to pick one up at?? Thank you this will be a big help.
moliver
Re: what is needed to change tranny fuild (spoolin2o)
Post by moliver » Sat Apr 30, 2005 1:17 pm
To remove the drain plug:Always remove the fill plug first (top).To remove its a 17 mm allen key, or a bolt with a 17mm hex head and a couple nuts jammed on it, or a Mac tool specifically for the job.
spoolin2o
Post by spoolin2o » Sat Apr 30, 2005 2:22 pm
yeah because i could not find a 17mm allen key around to buy to do the job myself, ill give that a shot tho with the 17mm hex bolt with the nuts jammed on and then use a wrench thank you.
gti337racer
Re: (spoolin2o)
Post by gti337racer » Tue May 03, 2005 5:40 am
what kind of fluid are you going to use?
Post by valladar » Mon Aug 06, 2018 3:08 am
zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047zo46047
zo46047zo46047
Post by valladar » Sat Oct 27, 2018 6:08 pm
