It is currently Sun Jan 21, 2018 10:58 pm
Reply to topic  [ 7 posts ]
Garage Clean out! Need this stuffs gone
Went through my garage and need to get rid of this stuff, its taking up too much space.
mk4 jetta/gti black floormats $30
SOLD!
mk4 jetta monster mats $50
SOLD!
mk3 gti/jetta 5x100 vr6 hubs with calipers/carries(came out of a 97 gti vr6) $160 for pair
mk3 vr6 power steering pump $30
mk3 gastank free
mk2 front wheel housings $5
brand new 1.8t oil pan without oil lever sensor $60
Audi TT gastank cap cover with cable and actuator $60
mk2/3 coolant reservoirs and mk2 washer tank $5 each
vr6 automatic transmission, has 68k miles on it. $800
mk3 vr6 plastic valve cover $15
mk3 vr6 timing chain covers, 1 lower 2 upper $10 each
mk3 vr6 obd2 auto ECU $100
mk3 vr6 obd2 vr6 5 spd ECU $100
Audi TT 225 1.8t throttle body $100
1.8t serpentine belt tensioner $20
Sold
obd2 vr6 head with 6 bent valves $100
mk4 12v vr6 maf with intake tube $50
mk3 vr6 obd2 maf sensor with intake tube $50
mk3 vr6 auto transmission starter $70
mk3 vr6 brand new hub $60
mk3 4x100 5 spoke wheels painted black $150
SOLD
2 mk3 vr6 radiators, $60 each and $xx with fans (Fans sold!)
b5 a4 1.8t engine cover $20
audi tt 1.8t engine cover $20
mk3 vr6 misc engine covers $5 each
upper 1.8t timing belt cover $10
1.8t mk4 pass side engine mount $40
mk4 dogbone mount $30
mk4 1.8t power steering pump with acc bracket $80
3 mk3/mk4 12v vr6 water pumps $30 each
mk2 foglights, one is busted but both brackets are there $20
sold!
mk3 driver's side airbag $20
4 mk3 vr6 front engine mounts $15 each
mk4 1.8t SAI pump with lines $30
mk4 1.8t combi valve $30
mk4 A/C compressor $40
mk3 vr6 SAI pump $20
mk3 vr6 ignition wires $25
mk4 12v vr6 ignition wires $30
Carbon Fiber 90 degree 3" elbow $30
mk4 Cold Air Intake $30
2 vr6 obd2 throttle bodies $50 each
2 mk3 vr6 obd2 intake manifolds, includes both lower and upper $100 each
3 ce2 fuseboxes, will come bare without fuses or relays $20 each
I have a lot more stuff that isn't posted. Feel free to contact me and ask. You can pm me here or txt/call 224 623 2067. Thanks.
:newhere:
Sat Jan 28, 2012 9:47 am
Interested in Carbon 3" elbow. Will let you know asap
SKYDude
08 R32
Mon Jan 30, 2012 12:50 pm
Let me know when you want to pick it up. My phone # is in the original post.
:newhere:
Wed Feb 01, 2012 8:53 am
Alloy rear calipers from a MKIV or normal mkIII one even ? The hubs/knuckles are tempting :)
Wed Feb 01, 2012 5:39 pm
no calipers, and buy the hubs
:newhere:
Sat Feb 04, 2012 12:07 pm
back up top :D
:newhere:
Tue Feb 14, 2012 8:15 am
This is very nice and cool post tahsnk for this ..........!!!!!!!!!!!!!!!!!!!!!!!!
192.168.o.1
Mon Jan 11, 2016 10:29 am
Users browsing this forum: No registered users and 4 guests
