Mostly Mk3 garage clean out, couple Mk4 and Mk2 parts
Have something VW/Audi related to sell? This is the place. No Ebay auctions please. All auctions will be deleted without notice.
kingbeann
Post by kingbeann » Wed Mar 21, 2012 3:08 pm
Updated 4/24/12 - new items added and more pictures. Sold stuff removed. If it is still listed it is still for sale. I may have other things too - contact me.
Most of these items will be compatible with other A3 VW’s such as the Golf, GTi, and Jetta. All come from my slow build of an ABA Jetta into an autocross car:
viewtopic.php?f=21&t=11164
Radio harness including OEM harness for trunk mounted CD player This is the OEM harness with all leads out to all speakers, antenna, and auxiliary CD player. The stereo system is also for sale. This harness was spliced into to install the aftermarket radio, but all wires are there.
Emergency brake light switch and harness This mounts under the handbrake lever to control the warning light on the dash if the e-brake is activated. Includes the harness to plug it in.
Trunk harness This is the wiring harness that runs within the trunk with the exception of the license plate lights. Plugs in to the trunk pop motor and backup lamps.
Trunk struts Work perfect, super strong to keep your trunk from falling on your head!
Power door lock system including vacuum pump and all lines. This doesn’t include the electrical switches, but let me know if you are looking for the electrics. $15 for the full power door lock vacuum system.
Two hubcaps. From 14” steel wheels on VW Jetta GL $2 each
Vacuum Reservoir for AC system. Comes with vacuum lines. Mounts behind left side fender liner. $5
Side marker lamp – perfect condition with no broken tabs, original orange Hella reflector housings $5
Prothane 22-702 Polyurethane Steering Rack Bushing Kit for 1985-1992 Volkswagen Golf and Jetta. Since they are made of polyurethane, the bushings will last the life of the vehicle. Install using factory procedures.
$10
Mk3 Jetta Interior, Rear seats, Door cards, etc. Upper light gray, lower dark gray interior pieces - Headliner, grab handles, sun visors, courtesy light, and plastic trim pieces for A, B, and C pillars that help hold up the headliner. Door sill pieces, trim around seat belts. Full trunk interior, parcel shelf with car seat latches, and rear seatbelts. Underdash trim panels and padding – including all the plastic separators and foam pieces under the driver’s side of the dash to keep everything clean and quiet. Basically any trim you need for an A3 VW! The plastic is clean but the headliner needs to be wiped down.
$ Let me know what you need, will sell the whole lot cheap, or if you just need specific things we can talk. I don’t have pictures of everything here, but everything is available.
Rear door contents – door bars, harness, vacuum hoses for locks, clips, whatever you need!
Mk3 blank out buttons These go next to the OBD2 port and cover where things like rear window controls, AC switches, and defrost buttons go. These are OEM. There are 4 of the normal size and one longer one. I tried to capture the part #’s on the picture of the backs. $1 each
Dash mounted Rear power window control switches and Recirculate/ AC switch These are the things that the blank out buttons replace (above). $4 each
Trunk pop switch and harness for it. $5
Trunk lock motor $5
HVAC vents Vents under the carpet/seats to direct air toward the back seat plus face level dash vents. $5 for all venting, $5 for dash insert piece.
Power window motor + regulator for driver’s side (left side) rear door. Works great. $15 + shipping
The picture is from the passenger side, which is already sold, but illustrative of the driver’s side.
Radio and wiring – Includes everything needed to run a stereo in your car. Stereo unit is a Sanyo with tape deck and CD controller (if you have an external CD player). (2) small round tweeters from the parcel shelf, (2) more round tweeters in a bigger housing from the dash, (2) round 6.5” speakers from doors, (2) round speakers mounted to the parcel shelf in the trunk. Also the antenna, antenna housing, ground wiring, and frames to mount the speakers in the doorshell. These are all OEM VW parts, but can work in anything. $10 for everything stereo related.
Note that there is a speaker or two missing from the picture, I’ll have those pulled out of the car and ready to deliver.
Wiring! I have the wiring and switches for most everything contact me if you need something not specifically listed.
Vibration dampener from k-member This is the heavy hunk of metal bolted to the k-member that helps reduce noise, vibration, and drones from the drivetrain. $3
Emissions secondary air injection pump This includes a working pump, the electrical plug/wiring that activate it, and the hoses that pull fresh air from the air box and pump it to the exhaust manifold. I also have the OEM exhaust manifold. $20 for pump, piping, and electrical plug.
Warm air injection/exhaust manifold heat shield This is the heat shield at the top of the exhaust manifold, the hose connecting the air intake filter box to the heat shield, and the flap valve that opens/closes to allow quicker warmup of the engine in cool weather.
Muffler heat shield Protects your floor boards from heat, I also have some of the pop-in/screw-off clips that hold these in if you need them. $2
I also have other small random parts and pieces available that aren’t required for a race car, contact me if you need anything small or not listed here.
1.8tedMila
Re: Mostly Mk3 garage clean out, couple Mk4 and Mk2 parts
Post by 1.8tedMila » Fri Mar 23, 2012 7:04 pm
Intrested in all the AC parts! PM me
Logan
kingbeann
Post by kingbeann » Fri Mar 23, 2012 8:22 pm
1.8tedMila wrote:Intrested in all the AC parts! PM me
PM'ed. You can call or text for quickest response. I'm right by Mobile One.
kingbeann
Post by kingbeann » Wed Apr 18, 2012 9:17 am
Updated with new stuff and new pics. If it is still listed it is still for sale!
kingbeann
Post by kingbeann » Tue Apr 24, 2012 1:48 pm
Updated with new stuff as it comes off the car. Sold stuff removed.
kingbeann
Post by kingbeann » Sun May 06, 2012 1:50 pm
bump
Christopherlewis
Post by Christopherlewis » Thu Mar 21, 2013 12:37 am
kingbeann wrote:Updated 4/24/12 - new items added and more pictures. Sold stuff removed. If it is still listed it is still for sale. I may have other things too - contact me.
speakers. This harness was spliced into to install the aftermarket radio, but all wires are there.
$10
Trunk lock motor $5
Which parts do you still have? I am very much interested so waiting for quick reply
kailey
Post by kailey » Tue May 08, 2018 1:59 am
environment, healthy coach bags personality nfl chiefs and psychological nfl titans development coach outlet en ligne and coach outlet harmonization nike air max 2015 in iphone 4s cases line adidas with the new balance shoes age characteristics.We can not nike mercurial vapor control nike air max the vibram shoes weather, timberland shoes but we can thomas sabo uk change the occhiali oakley mood; we can air jordans not change adidas shoes the face, but nfl rams we puma can show mcm handbags a the north face smile; belstaff we asics gel can nfl jets not nfl texans control others, but oakley sunglasses cheap we roche run can prada outlet control their own; we michael kors can tods mens shoes not change ferragamo shoes the environment, but we can change ray ban sunglasses their own; nfl lions we can not predict jerseys from china tomorrow, asics but we pandora bracelets can use today; we hollister co can not determine birkenstock taschen outlet the plein outlet length of birkenstock taschen deutschland life, cheap jerseys but bottega veneta we can control adidas sneakers its coach outlet width.Heart can nfl redskins not reebok tolerate burberry handbags others, in fact, hurt their own; guess jeans all day burberry sale complaining about swarovski jewelry fate, as ralph lauren uk real kate spade efforts. Create a good womens hoodies life needs a good juicy couture attitude, long champ maintaining asics harmonious jordans for sale interpersonal relationships mizuno running need converse outlet a good attitude, the converse achievements of cheap basketball shoes the polo ralph lauren outlet future nfl bills needs knicks jerseys of mbt shoes outlet the future ugg australia good pandora attitude, let nike outlet us start from ourselves, fred perry every moment hermes outlet of every versace shoes outlet day pandora rings is nike huarache changed from the louboutin start, juicy couture clothings for houston rockets the new balance achievements of bcbg dresses their birkenstock outlet own bright future.I pistons jersey sat in michael kors purses the fall nike.de of coach outlet arms, ralph lauren factory store in the north face outlet memory of nfl packers that ralph lauren shirts field in toms shoes outlet the dansko shoes shallow autumn free run blooming, soccer outlet online Cantabile michaelkors.com poetic lacoste polos aesthetic air jordan retro and solitude. --InscriptionShallow autumn cool earthI'm with nba jerseys you face to giuseppe shoes face. Watching kevin durant shoeskobe bryant shoes this season of adidas neo full and north face honest.But mcm outlet I chi hair do gucci womens shoes not know that nfl seahawks looking oakley sunglasses first zero howling Araara. memphis grizzlies Me ray ban sunglasses and adidas.de you, run in the opposite cheap nike shoes direction, missed polo ralph lauren the michael kors handbags season.GAO is still the michael kors outlet online sale sky is still pandora landing jerseys from china leaves. nfl panthers Lie longchamp sadness ecco women shoes lined unfeeling.I know I unload nfl broncos heavy tonnages of love babyliss in this autumn. michael kors bags Only oakley outlet for nike.dk the nba jerseys outlet abundance and enrichment designer handbags of prada the burberry outlet online season. But nfl colts unexpectedly, replica watches such flat iron as fendi outlet online going uggs through softball bats a michael kors outlet online difficult nike roshe journey.After philadelphia 76ers jersey all, I portland trail blazers was homeless from nike.com outside the season, philipp plein clothes such burberry handbags as cheap jerseys wrinkles sounded replica watches bare hillside cheap oakley sunglasses tracts cheap true religion of converse chucks age spots. Withered almost to cruelty.As levis outlet store if prada outlet there burberry handbags has charlotte hornets jersey never nfl jaguars been barbour women jackets lonely in the sky burning a michael kors outlet online lot michael kors of engulfed air jordan my nfl jerseys soul wreckage.Behind the years, baseball jerseys is still in ray ban sunglasses the russell westbrook jersey text rayban sunglasses of marc jacobs outlet the hilfiger bumps, and I have kobe bryant jersey nothing ray ban sunglasses to hollister kids rows fake rolex of a list of cheap true religion stories.I ralph lauren try jack wolfskin outlet online to longchamp taschen want coach outlet online to nfl azcardinals go farther, in nfl ravens faraway places, burberry handbags do a nba jerseys pull ray ban outlet farewell.Shallow autumn dreamDo not always in my toms shoes words to find my shadow, how could lunette oakley pas cher I polo ralph lauren let myself suns jerseys do nfl dolphins word jordan shoes in oakley outlet online the giuseppe zanotti puppet?Every cheap oakley sunglasses expression, are nothing air max but a tea ralph lauren millet barbour women jackets style. nike air max It seems I Fall nfl bengals in bos jersey love with nfl chargers this ralph lauren text, michael kors bags even hopeless.Do not underestimate this nike max shallow autumn, I san antonio spurs caressed baseball bats its vans shoes temperature, michael kors purses it mont blanc seems to ralph lauren uk have michael kors touched those who have mcm backpack outlet past. reebok shoes With nfl eagles you, hollister with roshe run me, rolex I could nike free run not c&c beanies wholesale bear throwing this thread warmth.I hogan always nop jerseys believe that rayban I do not hollister online shop deutschland have guess bags outlet a barbour mens jackets biting affair, as new balance store a timberland homme blooming belstaff mens jackets blooming, tommy hilfiger online shop deep and prada sunglasses shallow shoes on sale up early to salomon schuhe see louboutin shoes the belstaff sale sunrise rolex replica idea air jordan shoes appears, cheap glasses you thomas sabo can roshes do? If guciheaven you live in louboutin the city, roshe run in timberland boots the ray ban outlet morning I abercrombie do northface not know christian louboutin where nfl patriots to burberry play, swarovski had calvin klein changed the quality - burberry online shop Condominium claimed horizon, gray coach outlet dust air max 95 in nfl saints the north face jackets air nba jerseys there longchamp outlet is always a nike store greasy true religion jeans outlet feeling toms outlet tired, there is ed hardy clothing always michael kors play cheap oakley the new balance ghost of gasoline, toms outlet even red bottoms though ray ban sbocco cover utah jazz their nfl bears ears, can not hollister hold nike air max 2014 a www.tommyhilfiger.nl taxi horn, there parajumpers outlet online is no nike air max real night, nfl giants naturally it mcm bags does not hilfiger outlet matter really dawn michael kors purses ...... no coach factory outlet online dirt, no mountains, michael kors v?skor wilderness, no jordan release dates Jia nfl cowboys Qing, nike mercurial only the rough hogan shoes outlet black washington wizards cement cheap jerseys and true religion reinforced brick fred perry shoes you polo ralph lauren outlet unaware of polo ralph lauren the "new", nike free shoes even though north face pas cher his woolrich outlet online eyes open, supra shoes as hugo boss outlet in nfl vikings the air max 90 still tory burch sale drowsy ray ban wayfarer sleep, but, under armour curry in most cases, montre pas cher we ignore the existence of ralph lauren tracksuits everything tommy hilfiger outlet stores around: can dallas mavericks jersey not see blue sky, white clouds, michael kors australia can not cheap michael kors see the pandora jewellery trees, flowers ...... nike roshe ...Emerson hermes bags in "On kanye west shoes the Nature" Mean: "In thomas sabo fact, very few adults oakley sunglasses outlet can air max shoes really milwaukee bucks see nature, most cheap oakley people nike tn requin do replica handbags not look replica rolex at swarovski the michael kors canada sun carefully, at most they wholesale handbags are cheap ray ban just skimming pandora over armani clothing the coach outlet online sun jack wolfskin would huaraches illuminate adulthood. coach outlet sale the human the north face eye, polo outlet online but nfl 49ers it will shine into the dsquared2 jeans soul michaelkors.com through salvatore ferragamo the eyes of a stone island store child. people really oakley sunglasses outlet love oakley sunglasses nature, swarovski is the longchamp handbags kind michael kors outlet of bcbg max azria feeling louboutin outlet inside and outside swarovski crystal are coordinated person, still adidas shoes outlet playful spirit is the kind of real nike air force adult iphone 5 cases people. mont blanc pens "However, minnesota timberwolves in celine handbags modern community who bottega can do it? nike air force Like valentino shoes outlet Flaubert, tommy hilfiger Thoreau, Edwards ...... I even zapatillas nike sure, if they were prada handbags alive converse shoes today, and ralph lauren outlet we must nike.se have chicago bulls the same.Therefore, no true religion outlet matter ralph lauren when cheap eyeglasses and nike air max where, we can only restore childlike denver nuggets curiosity versace outlet and innocence? north face outlet Only sac jerseys the ralph lauren online clear nfl buccaneers sunlight ralph lauren polo as hermes birkin children can katespade outlet be north face backpacks found in mcm bags this supra footwear world, the north face in michael kors outlet online sale order to michael kors outlet online see coach factory online more skechers womens shoes than usual, in adidas.se order to watch coach factory outlet online the event coach black friday from dsquared2 shoes the adidas superstar most mundane nets jersey to skechers the rayban magical and replica watches beautiful. fitflop The fidget spinner adult mizuno running shoes world, coach factory outlet online almost barbour outlet lacking coach purses a coach factory outlet online real oakley vivid christian louboutin shoes natural, only ray ban zonnebril the rules longchamp of the game, air max only with people cheap michael kors of cheap oakley sunglasses experience chrome hearts jewelry and salvatore ferragamo logic.However, honorable shop coach factory adults, links of london bracelets it watches must swarovski australia be the christian louboutin kind of new balance "adulthood still playful jimmy choo shoes spirit of man", it must mia jersey be able kate spade outlet to toms shoes seize their one nike free 5.0 day marc jacobs handbags of people.When nfl falcons one true religion jeans women day a under armour ua shoes monk burberry clock air max 2014 hit oakley prescription one burberry outlet online thought givenchy bags outlet dawdle; ferragamo the relojes especiales other longchamp outlet is the body in its place, not nike huaraches their government, instead burberry outlet of nike outlet store complaining, high this treatment, the good job, also said jerseys from china that when the leadership is not simple, tory burch shoes if I have the nfl raiders opportunity Hermes to when scarpe hogan the timberland outlet leader, orlando magic I am kate spade outlet online not worse than puma outlet store them, ray bans and soccer shoes some ferragamo outlet even think that I nike air can be cleveland cavaliers jerseys a nike online manager, michael kors bags take polo ralph lauren outlet online 100,000 annual hollister clothing store salary, gucci mens shoes how moncler outlet online wonderful!In burberry uk fact there gafas oakley is barbour mens jackets a pandora rings kind indiana pacers of reason, vans outlet any ralph lauren outlet online person in nfl steelers a omega watches position nfl browns of leadership cadres, we should tommy hilfiger say skechers is a ray ban step by gsw jerseys step ray ban according jimmy choo to their ray ban sunglasses outlet ability to uhren break designer handbags out of the free running same operator, toronto raptors he toms outlet carefully than los angeles clippers others, cheap jerseys so vans schuhe he moncler women jackets became oakley the squad leader; the same squad, his burberry outlet online management in place than others, lacoste shirts so ralph lauren outlet he polo ralph became lunette ray ban pas cher a deputy nike air
Post by kakakaoo » Thu Aug 09, 2018 9:19 pm
adidas nmd shoes
hermens bags
uggs canada
nike free 4.0
cleveland indians jerseys
hermes handbags
minnesota twins jerseys
colorado rockies jerseys
coach factorty outlet
los angeles angels jerseys
nike air max 95
fred perry
chicago white sox jerseys
cristiano ronaldo jerseys
ecco shoes for men
houston astros jerseys
mulberry outlet
nike air max 87
air max 2019
cheap mlb jerseys china
nike air max shoes
converse outlet store
philipp plein shirt
hermes birkin
supreme new york
los angeles dodgers jerseys
abercrombie and fitch
arizona diamondbacks jerseys
cincinnati reds jerseys
tory burch outlet
kyrie 4 shoes
salomon shoes
coach outlet store online clearances
atlanta braves jerseys
new york mets jerseys
louis vuitton
air max 2017
louis vuitton
tiffany and co
ultra boost
underarmour shoes
asics shoes
tory burch outlet
birkenstocks
air max 2018
tiffany and co
toronto blue jays jerseys
red bottoms shoes
adidas campus
oakland athletics jerseys
pandora jewelry official site
san diego padres jerseys
polo outlet store
pg 2
baltimore orioles jerseys
ray ban sunglasses discount
jordan retro 11
birkenstock
seattle mariners jerseys
pittsburgh pirates jerseys
florida marlins jerseys
air max 2018
replica watches
cartier outlet
nike air max outlet
adidas
ralph lauren sale clearance
kansas city royals jerseys
dr martens outlet
milwaukee brewers jerseys
tory burch outlet
tampa bay devil rays jerseys
pandora
texas rangers jersey
nike air more money
hermes handbags
kobe bryant shoes
pandora store
cheap nike air max
hermes handbags
cheap ray bans
coach
gucci outlet
yeezy 350 boost
180810yueqin
Post by kakakaoo » Fri Aug 10, 2018 6:02 am
Re: 2018
Post by kakakaoo » Thu Sep 20, 2018 5:37 am
20180920 junda
links of london
clippers jerseys
lacoste soldes
coach handbags
giuseppe zanotti outlet
air jordan 4
tory burch outlet
van cleef & arpels jewelry
tory burch outlet
coach handbags
kings jerseys
indianapolis colts jerseys
le coq sportif shoes
cheap snapbacks
nike roshe one
harden shoes
palladium boots
cheap jerseys
adidas trainers
celtics jerseys
adidas wings
mavericks jerseys
chelsea jersey
gucci outlet
tory burch outlet
jazz jerseys
cheap jerseys
jack wolfskin
ralph lauren pas cher
kappa clothing
five fingers shoes
undefeated clothing
pacers jerseys
denver broncos jerseys
mulberry outlet
stephen curry shoes
hawks jerseys
spurs jerseys
cazal sunglasses
nobis outlet
grizzlies jerseys
camel shoes
Post by kakakaoo » Mon Oct 08, 2018 9:25 pm
